#141278 - 09/02/2003 10:10 ? GPSapp runs but...
rowitech
Loc: Germany, Cologne
Hi,
I set up preinit and all the stuff for let emptris work.
Also after a reboot all works fine because of M10emptris and so on. I just installed gpsapp in the same way. Copied the gpsapp file (and nothing else) to /programs0, started it an it worked. It appeared in the hijack-menu and all was cool.
Then I started to create my M80gpsapp, so it was there even after a reboot.
So far so good.
When I plug in my serial GPS-mouse I hear many beeps. Whoops! My GPS is steering my empeg. Oh, of course I can steer it via the serial port. What do I against this?
What is the difference between my way with M80gpsapp and the @EXEC_ONCE in the ini? Do they do the same?
I don't want the maps because there seems to be no map for germany, but to get the coordinates is also cool for the first start.
Oh, it may be discussed earlier, but I didn't found it. Really.
regards,
Rolf
Connecting Empeg via Bluetooth or Wireless LAN http://empeg.rowi.net
*** Proud owner of the European Worst Install Trophy 2003 ! ***
RoWi
#141279 - 09/02/2003 11:54 Re: ? GPSapp runs but... [Re: rowitech]
rowitech
Ok,
I found out that in DC mode the steering is not possible so that GPS may work. But the other questions are still there...
regards,
Rolf
RoWi
