I couldn't get the script to work so I just uploaded the file. I tried setting the permissions to 755 but it still doesn't show up.
here's the log I don't see anything that sounds like it would be related to this but I am an expert by no means.
empeg-car bootstrap v1.02 20001106 (
[email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v312 (root@ibbm) (gcc version 2.95
.3 20010315 (release)) #2 Tue Feb 4 20:03:25 EST 2003
Processor: Intel StrongARM-1100 revisi
empeg-car player (hardware revision 9, serial number 10101230)
Command line: mem=16m
Memory: 14996k/16M available (992k code, 20k reserved, 372k data, 4k init)
Linux NET4.0 for Linux 2.2
Based upon Swansea Universit
IP Protocols: ICMP, UDP, TCP
IrCOMM protocol (Dag Brattli)
Starting kswapd v 1.5
Signature is 20706d65 'emp '
Found custom animation at offset 0x99b78
empeg display initi
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005180).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DJSA-220, ATA DISK drive
ide0 at 0x000-0x007,0
hda: IBM-DJSA-220, 19077MB w/1874kB Cache, CHS=38760/16/63
smc chip id/revision 0x3349
smc9194.c:v0.12 03/06/96 by Erik Stahlman (
[email protected])
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:04:c
e
Partition check:
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...hange_root: old root has d_count=1
Mounting proc
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To CompěStartin
g player
khttpd: listening on port 80
kftpd: listening on port 21
Vcb: 0x4086d000
