#142456 - 11/02/2003 06:43 How do I change a constant 12V signal to a pulse?
rtundo
Loc: Albany, NY
What I'd like to do is take a simple mute signal from a cell phone (change to 12V from 0V) and have my stock head unit see only 12V for a few seconds. I want to put a resistor inline and mimic a "mute" button push from the steering wheel. I'd like a similar pulse of 12V when the phone is hung up and the voltage returns to OV. What I'm trying to avoid is a constant 12v signal to the headunit when this circuit is set up to see 12V for short periods (button pushes on the steering wheel). Can anyone help?
#142457 - 11/02/2003 11:54 Re: How do I change a constant 12V signal to a pul [Re: rtundo]
genixia
This is what you want?
Phone:
12V ----------------------------
0V.. -------------- --------------
HU:
12V -- --
0V.. --------------- -------------------------- -------------
Edited by genixia (11/02/2003 11:58)
#142458 - 11/02/2003 12:01 Re: How do I change a constant 12V signal to a pul [Re: genixia]
rtundo
Loc: Albany, NY
I'm not sure I understand your dashes.
Incoming call sends 12V from phone until call is over- this I want to translate into single 12V pulse to headunit like pushing mute switch on steering wheel.
When call is over phone returns to 0V - this I also want to translate to single 12V pulse like pushing mute on steering wheel.
Sorry if my explanation is a bit confusing.
#142459 - 11/02/2003 12:02 Re: How do I change a constant 12V signal to a pul [Re: rtundo]
rtundo
Loc: Albany, NY
Now I see what you are saying and it looks like that is what I want.
#142460 - 11/02/2003 12:05 Re: How do I change a constant 12V signal to a pul [Re: rtundo]
Is there some reason I'm missing that you don't want to use the built-in mute line on the empeg?
#142461 - 11/02/2003 12:10 Re: How do I change a constant 12V signal to a pul [Re: wfaulk]
rtundo
Loc: Albany, NY
The empeg is set up as an auxillary device playing through the stock headunit. Muting the empeg therefore does not mute the stock headunit. I wanted to see if I can mute/unmute the headunit the same way as the steering wheel controls using the correct resistance.
#142462 - 11/02/2003 12:53 Re: How do I change a constant 12V signal to a pul [Re: rtundo]
genixia
A simple resistor won't do it....
You'll need an RC differentiator feeding a zero crossing detector.
The differentiator will convert the one long positive pulse into 2 pulses at the transitions, the first will be positive, and the second negative.
The ZCD will give a positive pulse each time that signal hits zero.
Unfortunately it's not a simple mug-handed solder job - you'd need to be comfortable with laying out a circuit on perfboard... ?
#142463 - 11/02/2003 13:37 Re: How do I change a constant 12V signal to a pul [Re: genixia]
jaharkes
Won't a NE555 work nicely when wired up as a monostable one shot pulse generator?
Trigger one pulse from the rising edge of the 12V signal and use a second 555 to generate the other pulse from the falling edge. I haven't played with these things in a long time, but this link might have some useful references http://courses.ece.uiuc.edu/cubesat/555timer.htm There even was a dip package with 2 555's (NE565 or something?)
#142464 - 11/02/2003 13:45 Re: How do I change a constant 12V signal to a pul [Re: jaharkes]
rtundo
Loc: Albany, NY
Thanks guys,
I'll check into both of those suggestions.
#142465 - 11/02/2003 13:47 Re: How do I change a constant 12V signal to a pul [Re: jaharkes]
genixia
Yeah I suppose you could do it that way with the outputs OR'd together. Still needs a circuit laid out though.
#142466 - 11/02/2003 13:49 Re: How do I change a constant 12V signal to a pul [Re: genixia]
rtundo
Loc: Albany, NY
Oh by the way, to clear up my bad explanation..the resistor simply is to mimic a known value resistance to fool the headunit into thinking it was the mute button from the steering wheel remote not as a solution to creating a pulse. Thanks for the input, I am very interested in how people would approach this problem (even if it is above my electronic skills).
#142467 - 11/02/2003 13:55 Re: How do I change a constant 12V signal to a pul [Re: jaharkes]
NE556 I think. Doesn't save you that much space though as it's basically two NE555's stuck into a single package. There are quite a few equivalent chips out there from other manufacturers though so look around.
If it was me I'd just program a PIC chip to do it. But that's way overkill for this but it's nice and simple
- Trevor
#142468 - 11/02/2003 13:58 Re: How do I change a constant 12V signal to a pul [Re: tman]
rtundo
Loc: Albany, NY
I was thinking about that. I have a leftover Basicx chip that I was using with Number6's help. Since I no longer need it, I should be able to write a simple program to send a pulse at the rising/falling edges of the 12V signal. Overkill, but since I have it sitting in a box anyway.
#142469 - 12/02/2003 04:04 Re: How do I change a constant 12V signal to a pul [Re: rtundo]
thinfourth2
Have you had a look round the back of the stock head unit it might have an cellphone mute as standard
#142470 - 12/02/2003 06:16 Re: How do I change a constant 12V signal to a pul [Re: thinfourth2]
rtundo
Loc: Albany, NY
Unfortunately GM headunits don't have a mute connection.
