#142555 - 11/02/2003 15:17 It doesn't work!!!
I've built the tuner but when I fire my empeg up, the light on the tuner goes on but it flickers 'Radio Not Found' and continues, I can't get a startup log because my serial cable won't fit in the back of the sled I'm using. Help!!!
There's nothing obvious amiss, I'm using beta13 and have hijack as well.
#142556 - 11/02/2003 15:29 Re: It doesn't work!!! [Re: andym]
Daria
Does it try for the tuner in AC mode? Did you try forcing DC?
#142557 - 11/02/2003 15:29 Re: It doesn't work!!! [Re: andym]
loren
First thing is to go back with a MultiMeter and double check every solder joint on the board i'd imagine.
|| loren ||
#142558 - 11/02/2003 15:40 Re: It doesn't work!!! [Re: andym]
Warp10
Loc: Germany
Also check the tuner's contacts at the sled plug.
cheers
thorsten
---------------------------- MK1: 00314 (4GB) MK2a: 030103104 (30GB) Installed in a BMW 323ti
#142559 - 11/02/2003 15:40 Re: It doesn't work!!! [Re: Daria]
I've forced it to DC, I'll just have to re-sweat all the joints.
#142560 - 11/02/2003 15:58 Re: It doesn't work!!! [Re: andym]
Right had a good look at the board, a couple of joints re-done, but still no joy. Are there any diagnostic tests I can do, managed to get a serial connecter in,
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
Uncompressing Linux................................... done, booting the kernel.
Linux version 2.2.14-rmk5-np17-empeg51-hijack-v291 ([email protected]) (gcc ve
rsion 2.95.3 20010315 (release)) #2 Wed Jul 31 10:10:42 EDT 2002
empeg-car player (hardware revision 9, serial number 10101731)
Command line: mem=16m
Memory: 15076k/16M available (928k code, 20k reserved, 356k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Found custom animation at offset 0x9877c
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005780).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IC25N040ATCS04-0, ATA DISK drive
hdb: TOSHIBA MK2018GAS, ATA DISK drive
hda: IC25N040ATCS04-0, 38154MB w/1768kB Cache, CHS=4864/255/63
hdb: TOSHIBA MK2018GAS, 19077MB w/0kB Cache, CHS=38760/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:06:c
3
Partition check:
empeg-pump v0.03 (19980601)
Freeing unused kernel memory: 4k init
empeg-preinit starting...
empeg-preinit complete
empeg init 0.8
Mounting proc
Starting player
empacman running as pid 21
/etc/preinit.d/M20emptris: /programs0/emptris: No such file or directory
/etc/preinit.d/M30emptriv: /programs0/emptriv/emptriv: No such file or directory
Vcb: 0x4086d000
! mp3_decoder.cpp :1049:Failed to find valid sync after seeking to offset 5673
33, error=0xc0044000
#142561 - 11/02/2003 16:05 Re: It doesn't work!!! [Re: andym]
Right, everyone repeat after me
HALLELUJAH!!!
It bloody works!!!!!!!!!!!!!!!!!!!!
#142562 - 11/02/2003 16:13 Re: It doesn't work!!! [Re: andym]
What was the problem ?
#142563 - 11/02/2003 16:31 Re: It doesn't work!!! [Re: msaeger]
Crossed over wire on the plug (doh!).
BTW, do you need a good signal to get RDS going?
#142564 - 11/02/2003 21:16 Re: It doesn't work!!! [Re: andym]
Daria
I've gotten errors in RDS when I was in a weak signal area, apparent missed bits. I'm guessing it uses some weak form of checksumming. I assume a really weak signal simply wouldn't decode.
#142565 - 12/02/2003 02:19 Re: It doesn't work!!! [Re: Daria]
My G/F's Sony is quite good at picking up RDS, the empeg seems a little picky.
