#153632 - 07/04/2003 08:59 Emplode 'Created' Column Doesn't Adjust For +-GMT
Chuck
I've already let Roger know about this, so I'm posting it here just in case, so it doesn't get overlooked. I don't know if it's on the internal bug list or not.
The 'Created' column in Emplode doesn't subtract/add the GMT offset. A tune I added at 4:00pm shows being added at 10:00pm (my GMT offset is -6). The 'Last Played' dates are showing up correctly though, played at 1:00pm shows 1:00pm. My player's time zone is set at GMT.
-Chuck
#153633 - 07/04/2003 09:43 Re: Emplode 'Created' Column Doesn't Adjust For +-GMT [Re: Chuck]
(my GMT offset is -6) [...] My player's time zone is set at GMT.
Are you sure this isn't the problem? What happens if you set the correct timezone on your player?
#153634 - 07/04/2003 11:18 Re: Emplode 'Created' Column Doesn't Adjust For +-GMT [Re: peter]
Chuck
Setting the timezone on the player yields the same results. Just double checked it to make sure.
#153635 - 07/04/2003 12:21 Re: Emplode 'Created' Column Doesn't Adjust For +- [Re: Chuck]
Just to make double sure, are you saying that tracks downloaded while your player was set correctly still get the wrong time? Tracks downloaded while the player was set incorrectly will stay incorrect.
To me what you describe sounds like normal behaviour. If your player is set to timezone GMT, but the clock looks right to you, that means the player's internal GMT clock is set wrong by six hours. When you do your downloads at 4pm your time, it is indeed 10pm in London, and your player is faithfully telling you so.
Edit: I'm not saying there definitely isn't a bug here, I'm just saying we've not proved it yet.
#153636 - 07/04/2003 13:23 Re: Emplode 'Created' Column Doesn't Adjust For +- [Re: peter]
Chuck
Triple checked.
1. PC set to local time zone
2. PC clock set to correct local time
3. Empeg set to local time zone
4. Empeg clock set to correct local time
5. Power off/on player and check settings are as above
6. Add tune at 4:00pm (Emplode 'Created' column displays '10:00pm')
7. Sync
7. After sync, Emplode 'Created' column displays '10:00pm'
#153637 - 07/04/2003 13:28 Re: Emplode 'Created' Column Doesn't Adjust For +- [Re: Chuck]
OK, it's a fair cop. I'll find and reopen the bug. But if your original bug report had said this, we'd have fixed it for 2.0!
#153638 - 07/04/2003 14:11 Re: Emplode 'Created' Column Doesn't Adjust For +- [Re: peter]
Chuck
That's no excuse!
Seriously though, I'm just grateful that you guys are still working on this.
-Chuck
