#155576 - 16/04/2003 05:27 Need help with [ir_translate]
puckalicious
Ok first off I'm not too smart with hacking and programming things.
That being said, this is what I'm trying to do. I have my stock steering wheel stereo controls working on my mk2 by using one of those PAC steering wheel remote adapters. I have mapped the rio remote buttons for volume up and down to the steering wheel volume up and down.
The current behavior is each press of the volume up/down translates into a small increment of actual volume up/down, and holding the volume up/down seems to repeat the command and gives a slow progression of volume increase/decrease.
I have added the following to my config.ini :
[ir_translate]
Vol+=Vol+,Vol+,Vol+,Vol+,Vol+
Vol-=Vol-,Vol-,Vol-,Vol-,Vol-
As expected, this generates a greater change of volume with each push of volume up/down. However, when I hold down the volume button it still increases at the same old slow rate.
Any ideas on how to have the volume change quicker when holding the button?
#155577 - 16/04/2003 07:29 Re: Need help with [ir_translate] [Re: puckalicious]
Maybe use a Vol+.L and Vol-.L? This is just a guess, though.
#155578 - 16/04/2003 11:16 Re: Need help with [ir_translate] [Re: wfaulk]
Bitt is probably right. The long presses are handled in IR_translate separately. Make sure to read the notes in the FAQ about the ordering of the items in the ini file.
Although I think what this will do is cause a 1sec delay before your short volume presses are registered. Not sure.
#155579 - 16/04/2003 19:00 Re: Need help with [ir_translate] [Re: tfabris]
puckalicious
Ok thanks for the suggestion, I will try this and post my results.
#155580 - 23/04/2003 14:24 Re: Need help with [ir_translate] [Re: puckalicious]
puckalicious
Ok I finally got around to checking this out. The Vol-.L and Vol+.L don't change the long press behavior, and I ordered them correctly. I added ",null" to the long press and it causes the 1 sec. delay described, and then will continue increasing/decreasing the volume even if the button is released. Still does this at the original, slow rate though.
Out of curiosity, is there a difference between "Vol+" and "VolUp"? And how do I get the volume to increase in greater steps when changed from the knob?
#155581 - 23/04/2003 14:30 Re: Need help with [ir_translate] [Re: puckalicious]
This was a known bug in one of the older releases of hijack that has since been fixed. What version are you running?
#155582 - 24/04/2003 04:44 Re: Need help with [ir_translate] [Re: tfabris]
puckalicious
I don't know the exact version, but it was the latest available 2-3 weeks ago. I also have the latest empeg software.
#155583 - 24/04/2003 08:54 Re: Need help with [ir_translate] [Re: puckalicious]
The bugfix I am referring to was more recent than that. I think you should upgrade to the latest Hijack and try your IR translations again. They might work.
#155584 - 25/04/2003 06:18 Re: Need help with [ir_translate] [Re: tfabris]
puckalicious
Well I have v333 now and the behavior is the same. I tried Vol+.L=Vol+.L inserted before the normal Vol+ line and it still changes the volume at the slow rate. Is there a separate function controlling the volume rate of change?
#155585 - 25/04/2003 07:33 Re: Need help with [ir_translate] [Re: puckalicious]
Mmm.. the "repeat rate" for a longpress is determined inside the player software, so I don't think translating it is gonna make much difference here.
Perhaps someday I'll tackle an alternative method of handling this.. like maybe just completely hijack the volume control into Hijack. Period.
#155586 - 25/04/2003 08:29 Re: Need help with [ir_translate] [Re: mlord]
puckalicious
That would be sweet! My money is on release #438. Hopefully sooner if I sacrifice a virgin to the hijack gods. Er, hijack god.
#155587 - 25/04/2003 09:34 Re: Need help with [ir_translate] [Re: puckalicious]
"lord", not "god".
And that's "M'Lord" to you!
#155588 - 25/04/2003 11:13 Re: Need help with [ir_translate] [Re: mlord]
Nice. Then we can hack it so that it goes up to eleven.
#155589 - 25/04/2003 11:30 Re: Need help with [ir_translate] [Re: tonyc]
Jeez, it's already GOT that.
#155590 - 25/04/2003 11:35 Re: Need help with [ir_translate] [Re: tfabris]
Yeah but it doesn't SAY eleven.
#155591 - 25/04/2003 13:31 Re: Need help with [ir_translate] [Re: tonyc]
genixia
hj-spinal_tap.patch
cd /path/to/hijack_source
patch -p1 < /path/to/hj-spinal_tap.patch
155292-hj-spinal_tap.patch (178 downloads)
#155592 - 25/04/2003 13:37 Re: Need help with [ir_translate] [Re: genixia]
- { 0x800, 0xe6c, 1000 }, /* 10.0 dB intensity 1000000.000000 */
+ { 0x800, 0xe6c, 1100 }, /* 10.0 dB intensity 1000000.000000 */
ROFL
#155593 - 25/04/2003 14:38 Re: Need help with [ir_translate] [Re: genixia]
hahaha. I like it. If only the display actually showed the numbers 0 through 11..
