#156061 - 18/04/2003 09:25 Error since 2.0 upgrade
jets
Loc: Toronto, Canada
Hi there. I have upgraded to the 2.0 final software for the player but have stuck with HiJack v301. Since the upgrade there seems to be a boo boo somewhere. When I turn the knob counter-clockwise it studders the audio playback instead of cycling thru the visuals in reverse order. It's sorta like the player thinks it's in "seek tool" mode or something? There is no problem the the knob clockwise rotation though. Any ideas folks???
Here is the ir_translate from my config.ini:
[ir_translate]
PopUp0=Detail,KnobSeek,Mark,Repeat,Shuffle,Sound,Time,VolAdj,PopUp1
PopUp1=Artist,Album,Genre,Year,Popup0
KnobLeft.CM=Visual-.N,KnobLeft.U
KnobRight.CM=Visual.N,KnobRight.U
Knob.T=KnobSeek
Four.L=Bottom,Left,Left,Left,Left,Bottom
Visual.L=Bottom,Right,Right,Right,Bottom,Right
Cancel.L=Bottom,Left,Left,Left,Left,Left,Bottom
Search.L=Search,Search,Search,Null
Info=Bottom.L,Null
It seemed like a good idea at the time.
#156062 - 18/04/2003 10:01 Re: Error since 2.0 upgrade [Re: jets]
You're probably going to get the most help from Mark if you upgrade to the latest version of Hijack and work from there.
Programmers usually hate trying to support old versions of code.
The problem is most likely related to the fact that they changed the "Visual-" code in 2.0.
#156063 - 18/04/2003 10:55 Re: Error since 2.0 upgrade [Re: tfabris]
jets
Fair enuff I'm now using v332 and upon rebooting the player an ir_translate error was displayed. I removed the "-" from "visual-" and now there is no more error.
Only thing is I see no documentation in the FAQ as to what the new code for "visual-" is in v2.0?
#156064 - 18/04/2003 11:00 Re: Error since 2.0 upgrade [Re: jets]
Chimaera
Loc: DFW Area, Texas, US
does this help?
#156065 - 18/04/2003 11:01 Re: Error since 2.0 upgrade [Re: jets]
I'm not sure if it even needs a new code or not at all. I think the new IR code was added in 2.0 and then Mark updated his translation table so it all just worked. I could be wrong.
It's also built-in to his popup code, so you might not even need an IR translation to make it work, just put it in his popup menu.
#156066 - 18/04/2003 11:14 Re: Error since 2.0 upgrade [Re: tfabris]
jets
Holy moly..thats some fast replying!!!
Thanks guys...NextVisual and PrevVisual are werkin flawlessly!!!
#156067 - 18/04/2003 11:35 Re: Error since 2.0 upgrade [Re: jets]
It's "PrevVisual".
But even better is "VisualSeek".
#156068 - 18/04/2003 11:56 Re: Error since 2.0 upgrade [Re: mlord]
jets
VisualSeek is cool but since my unit is a "slave" unit in my HU setup the knob is a visual seeker instead of a volume knob.
Hmm...this'll probably work better with VisualSeek mapped to a long press of the visual button on the remote. Could one configure the next/previous track buttons on the remote to switch the visuals at that point?
#156069 - 18/04/2003 13:26 Re: Error since 2.0 upgrade [Re: jets]
I think it already works that way (VisualSeek)
#156070 - 19/04/2003 08:33 Re: Error since 2.0 upgrade [Re: mlord]
jets
That's cool. I can't test it until I find my remote
#156071 - 22/04/2003 10:06 Re: Error since 2.0 upgrade [Re: jets]
lopan
Loc: Manassas VA
I'm having an issue with the new software, when I'm using the tuner.... I can hit left and right to move between presets but holding them down has no effect (scan).... I can use the remote for some reason to move the channels up one number at a time... but no scan from remote either... is this a known issues? is something on my empeg set incorrectly?
Brett 60Gb MK2a with Led's
#156072 - 22/04/2003 10:08 Re: Error since 2.0 upgrade [Re: lopan]
It is a known issue, it's been reported elsewhere.
Somehow us alpha testers didn't catch it. I don't know whether it was in the release candidates that way or not.
#156073 - 22/04/2003 10:13 Re: Error since 2.0 upgrade [Re: tfabris]
lopan
Loc: Manassas VA
Maybe they just need more alpha testers... I suppose I'd volunteer, ya know take one for the team
It's no big deal, was just a bit of a pain setting all my stations up.
