#158353 - 01/05/2003 04:56 Help needed upgrading to 2.0 Final
pedrohoon
After unzipping the car-emplode-v2.00.zip file and double clicking on setup.exe I get an installshield error message:
1155:File C:\Empeg_V2.0_Final\INSTMSIA.EXE Not Found
Am I doing anything wrong? Thanks,
Peter.
#158354 - 01/05/2003 05:16 Re: Help needed upgrading to 2.0 Final [Re: pedrohoon]
Where did you get the .zip file from? Maybe try using the original .upgrade files from the "Latest Software" link above?
#158355 - 01/05/2003 05:29 Re: Help needed upgrading to 2.0 Final [Re: mlord]
pedrohoon
Hi Mark,
The zip file is the only file that is available under the "Download now" link for the emplode PC software on the empeg customer support site.
Peter.
#158356 - 01/05/2003 05:36 Re: Help needed upgrading to 2.0 Final [Re: pedrohoon]
mtempsch
I think Mark thought you meant the actual player file (that is a .upgrade file).
Check out these threads for info on the MS installer and 2.0 emplode issue:
Link 1
Link 2
#158357 - 01/05/2003 05:53 Re: Help needed upgrading to 2.0 Final [Re: mtempsch]
pedrohoon
Great, I'll try that.
Thanks for the pronto help both of you!
Peter.
#158358 - 01/05/2003 07:00 Re: Help needed upgrading to 2.0 Final [Re: pedrohoon]
pedrohoon
Yep, worked a treat! 2.0 up and running. Thanks again!
Peter.
