#161200 - 13/05/2003 09:48 Clone Successful on RioCar.org
CHiP
Just wanted to let you all know that i've had success cloning my empeg using this FAQ entry on riocar.org:
http://www.riocar.org/modules.php?op=modload&name=FAQ&file=index&myfaq=yes&id_cat=4&categories=Software+and+player+operation+questions&faqent=20#20
The post says:
"I've never actually done this, so the above procedures are untested. If you end up doing this yourself, please report your success or failure to the Empeg BBS so this FAQ entry can be corrected if necessary."
It worked perfectly for me by following the directions exactly. I even copied my eq, number of plays, and last played info with a single file. It was easy.
-CHiP
#161201 - 13/05/2003 09:58 Re: Clone Successful on RioCar.org [Re: CHiP]
Thanks! FAQ entry updated.
