#167731 - 25/06/2003 16:30 My player said "FSCK you!!!"
Ack!!!
I got hit with a surprise fsck tonight. Uploading 2.4GB of new music and a rather large audiobook, and it chooses now to do a disk check. And the partitions were not dirty. Ah well, I knew I was coming close to the number of mounts. Time to leave the player to sync overnight... Dual 80s will take (from experience) about 1.5 -> 2 hours.
I am just glad I didn't try this at the office!
#167732 - 25/06/2003 17:03 Re: My player said "FSCK you!!!" [Re: pgrzelak]
mrfixit
You just had to have all that space... didn't you!
Ben
hijacked
#167733 - 25/06/2003 17:10 Re: My player said "FSCK you!!!" [Re: pgrzelak]
BryanR
Loc: Berkshire, UK
And with similarly stunning timing, mine crashed as I was synching (my own fault), and now Emplode has been checking disk integrity for half an hour... and I really ought to get to sleep.
Serves me right for uploading a few albums just before going to bed, then messing around with my network settings as the synch was happening.
Yes, yes, I know I was being stupid, but I just wanted to check something, then noticed something else I'd been meaning to change, so changed it, then thought "Oh bugger, I'm still uploading". Mea culpa.
Bryan.
#167734 - 27/06/2003 17:18 Re: My player said "FSCK you!!!" [Re: BryanR]
Update:
I loaded a bunch of new tracks, and I got put through another FSCK cycle. Now, I know for a fact that I did not do anything that would have left the filesystems dirty. This is on my primary player, and it does not get moved much.
So, I am wondering if the disk check from the latest build is not clearing the dirty flags properly. Immediately after the check completes, I will go and look at the partitions. If what I suspect is true, something will still be marked as dirty or expired.
Note, I have hijack 334 and 2.0 developer on the player, but I have not disabled the fsck timing check through hijack.
#167735 - 27/06/2003 22:05 Re: My player said "FSCK you!!!" [Re: pgrzelak]
Might it be failing due to lack of memory like on Laura's due to your big disks?
#167736 - 28/06/2003 05:18 Re: My player said "FSCK you!!!" [Re: wfaulk]
I don't think so. The syncronization completes without any errors. I went into the player after the sync, and there was no sign of problems, the new files were there, etc. It looks completely clean.
I am performing a manual fsck now, just in case. Maybe I did do something stupid last night, and didn't realize it. It was a rough day, and I may have missed something.
#167737 - 28/06/2003 08:26 Re: My player said "FSCK you!!!" [Re: pgrzelak]
Aha!
You are right. Even though the drives were clean, I did an fsck from command line and received the following:
empeg:/empeg/bin# fsck -fay /drive0
Parallelizing fsck version 1.19 (13-Jul-2000)
e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
hda4 is mounted.
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
no room for private writable mapping
error: -12
fsck.ext2: Memory allocation failed while retrying to read bitmaps for /dev/hda4
empeg:/empeg/bin#
I would have expected a failed fsck to cause emplode to fail, but perhaps not. So I turned on swap, and will go from there.
Now, my question is: does emplode turn on swap when it attempts to fsck drives? If not, then other people with 80GB drives will start seeing this problem more frequently.
#167738 - 30/06/2003 04:02 Re: My player said "FSCK you!!!" [Re: pgrzelak]
skibum
Loc: Swindon, UK
Paul,
Have you thought of installing jfs/ext3 on your empeg's? I've been using hijack compiled with ext3 and fsck is a thing of the past.
#167739 - 30/06/2003 04:27 Re: My player said "FSCK you!!!" [Re: skibum]
Greetings!
I have been tempted, but I wanted to keep to a more standard install. As I experiment with different / new drive configurations, I like to try and find what breaks and why. This is one instance.
#167740 - 30/06/2003 05:36 Re: My player said "FSCK you!!!" [Re: pgrzelak]
IIRC, it does. But the player's still running, which might just push you over the edge, memory wise (even including the swap).
