#170443 - 13/07/2003 23:01 Tuner Antenna Help
Tyris
Loc: Texas, USA
Well, I've been assembling my tuner from PCA (great work by the way!) and it's now time to attach the antenna cable. Except... I don't see anything like the antenna cable described in the manual! There's a pre-assembled cable that looks as though it would fit an antenna, but it isn't described anywhere in the manual. I did some searching here, so sorry if this has been discussed. Thanks!
Tyris
MkIIa 10gb Blue - 040103702
#170444 - 14/07/2003 01:32 Re: Tuner Antenna Help [Re: Tyris]
If you have a premade cable, with a male connector on one end, and a female on the other, then you are supposed to cut it into two pieces (roughly in half, or whatever length you prefer), and then solder the appropriate half (female) to the tuner.
This was discussed here somewhere by Patrick et al, and a search may turn it up.
Perhaps Patrick could also add it to the tuner assembly manual, if not already there (?)
#170445 - 14/07/2003 01:34 Re: Tuner Antenna Help [Re: Tyris]
Edited by mlord (14/07/2003 01:36)
#170446 - 14/07/2003 04:52 Re: Tuner Antenna Help [Re: mlord]
Tyris
Loc: Texas, USA
I figured as much. Thanks for the help Mark, sorry I didn't look hard enough!
Tyris
