#170502 - 14/07/2003 11:22 problems with display-unit
coolblue
Loc: Switzerland
I have a problem with the display-unit.
The display has become dim.
After 1min running the text vanishes completely.
Then I see only the red lines on my display.
I already checked the three fuses near the display-connector with an ohmmeter.
They are all ok.
I made a test with my spare unit.
I changed the display-unit.
The fault is definitely on the display-unit.
Any suggestions ?
Andreas
#170503 - 14/07/2003 11:27 Re: problems with display-unit [Re: coolblue]
My guess would be the VFD itself (check the nipple and the glass to see if there is any sign of visible damage) or a capacitor problem on the display board. See the faulty VFD section of this FAQ entry for a way to test (if you have a multimeter handy).
#170504 - 14/07/2003 12:11 Re: problems with display-unit [Re: pgrzelak]
coolblue
Loc: Switzerland
Thanks for the hint
The nipple is ok.
It looks like the capacitor is faulty.
I have 20V instead of 60V
And when the text vanishes completely - There is only 14V.
Have someone experiences with that problem.
And is there an instruction how to change this capacitor.
Can I do this myself. (soldering iron is available)
Andreas
#170505 - 14/07/2003 12:18 Re: problems with display-unit [Re: coolblue]
You may still want to contact support. It might just be the one capacitor. In any case, Rob will be able to assist you further with this than I can.
#170506 - 14/07/2003 12:32 Re: problems with display-unit [Re: pgrzelak]
coolblue
Loc: Switzerland
Many thanks for your help.
I will contact rob for that problem.
Andreas
#170507 - 14/07/2003 15:03 Re: problems with display-unit [Re: coolblue]
schofiel
#170508 - 15/07/2003 06:04 Re: problems with display-unit [Re: schofiel]
thinfourth2
Are you going to go public on your company name ?
Or do you only find out when you call out "****" in vain as your empeg has died.
And on a second note did you get my mail ?
