#171534 - 21/07/2003 11:50 Help with cisco firewall
I think this is very basic for someone who has some ecperience with Cisco Firewalls.
I have a Cisco PIX515 and I want to set both it's "inside" and "outside" ethernet interfaces to 100 HALF duplex. I have all the passwords. What commands should I use?
On the switches I used to manage I did this:
config t
int fastethernet 0/1
speed 100
duplex half
<CTRL-Z>
write mem
done.
With the 515 PIX I can't get that far. I enter the config mode:
config t
then I see, by using "show int" that both the ethernet0 and ethernet1 interfaces are set to 100 full duplex. What should I do? "speed" and "duplex" commands are not available.
Thank you in advance...
#171535 - 21/07/2003 12:15 Re: Help with cisco firewall [Re: Taym]
genixia
Try;
interface ethernet0 100basetx—Set
show interface
#171536 - 21/07/2003 12:20 Re: Help with cisco firewall [Re: genixia]
Nothing.
Help says the command format is
interface <hardware_id> [<hw_speed> [<shutdown>]]
<hardware_id> is "ethernet0", since I dont' get any error up to that point.
<hw_speed> is not "100" since that gets not accepted. I don't know where the DUPLEX setting would fit.
#171537 - 21/07/2003 13:19 Re: Help with cisco firewall [Re: Taym]
ricin
Loc: US: CA
This help?
Looks like it should be:
<shrug>
Donato
MkII/080000565
MkIIa/010101253
ricin.us
#171538 - 21/07/2003 13:24 Re: Help with cisco firewall [Re: ricin]
genixia
LOL.
"100basetx—Set for 100 Mbps Ethernet half duplex communication"
The version of that page that I found when checking my facts had "100basetx--Set for 100 Mbps Ethernet half duplex communication".
Edited by genixia (21/07/2003 13:25)
#171539 - 21/07/2003 13:38 Re: Help with cisco firewall [Re: genixia]
ricin
Loc: US: CA
Cut and paste errors are always fun.
Donato
MkII/080000565
MkIIa/010101253
ricin.us
#171540 - 21/07/2003 16:39 Re: Help with cisco firewall [Re: ricin]
Thanks. I'll give it a try tomorrow morning...
#171541 - 22/07/2003 02:47 Re: Help with cisco firewall [Re: ricin]
Worked out great.
Thank you guys!
#171542 - 22/07/2003 09:21 Re: Help with cisco firewall [Re: Taym]
ricin
Loc: US: CA
Noooo problem.
Donato
MkII/080000565
MkIIa/010101253
ricin.us
