#171916 - 23/07/2003 19:35 Just out of curiosity.....
webroach
Loc: Colorado
...what would be the correct email address for technical support for Empegs? I spoke to Rob via email about a month ago, but now that address isn't generating any reply.
This is all in an attempt to get a new drive cable, as well as a backup cable if possible. My poor player fell prey to the "No Hard Disk" error. Below is a copy of the current boot log in case I'm barking up the wrong tree...
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.14-rmk5-np17-empeg49 ([email protected]) (gcc version 2.95.3 20010315 (release)) #130 Mon Oct 22 18:52:07 BST 2001
empeg-car player (hardware revision 9, serial number 40104034)
Command line: mem=16m
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004900).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:0f:c2
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...VFS: Cannot open root device 03:05
Kernel panic: VFS: Unable to mount root fs on 03:05
Just to clarify, I have read the FAQ, and can't find evidence of a dry solder point or other issues. The cable looks ok, but nothing else seems to be wrong, so....
Dave
#171917 - 23/07/2003 20:06 Re: Just out of curiosity..... [Re: webroach]
robricc
That would be [email protected]
#171918 - 23/07/2003 20:13 Re: Just out of curiosity..... [Re: robricc]
webroach
Loc: Colorado
Thanks much for the fast reply!!! Hopefully I can get the poor thing up and running again quickly now!
In time for the Colorado meet at the very least...
Dave
#171919 - 24/07/2003 08:43 Re: Just out of curiosity..... [Re: webroach]
There are instructions and pictures here of how to take care of this problem yourself, without needing a new cable from support, if you'd like to try it.
#171920 - 24/07/2003 09:39 Re: Just out of curiosity..... [Re: tfabris]
webroach
Loc: Colorado
Ok, to paraphrase Stan from South Park....
I've learned something today. It doesn't matter how many times you check Tony's FAQ, or read it. You always need to go back, because there's sure to be something new in there, something that can help. Heck, I'm just one kid in this crazy messed up world, but now I'm a kid who once again has a working Empeg.
Tony, seriously, thank you so much for pointing that out to me. I (stupidly) forgot that the FAQ is constantly evolving, and didn't think to check if you'd added more info on the "No Hard Disk Found" issue.
I'll still wanna get another cable, just in case this one get's worse, but right now everything is A-OK!
Thanks to all for the help!
Dave
#171921 - 24/07/2003 14:20 Re: Just out of curiosity..... [Re: webroach]
Hey, no problem. Glad you're up and working again.
I think that particular FAQ entry is the one that's gone through the most revisions, historically, along with the drive upgrade guide.
