#174682 - 11/08/2003 12:36 i lost all my music??!!!
frodo_lives
Loc: Fl
the player was in sync, and accidentally the power got shut off. as i tried to restart it, and run emplode again, it failed to read that my player had any music on it. even when i scroll thru my playlist on the player, it shows that there is none. is all my memory gone? all 25 gigs of music that i had on there so far? if not, how can i go about retreiving it? i already reloaded beta 2.0 on it, and that didnt help at all. what do i do?
Mk2-60Gig 89 Honda EF-9 JSpec
#174683 - 11/08/2003 12:46 Re: i lost all my music??!!! [Re: frodo_lives]
Does your player have one hard disk or two? If two, it might be this problem. It also could be this problem. Check those.
#174684 - 11/08/2003 12:52 Re: i lost all my music??!!! [Re: frodo_lives]
Loc: Los Angeles, CA
more than likely, since the sync didnt finish cleanly, the playlist didnt get generated. so the songs are probably orphaned. refs=0 in search show them.
#174685 - 11/08/2003 13:09 Re: i lost all my music??!!! [Re: image]
Would that happen if he had 25 gigs of stuff that was already on there? Would it lose/ruin an existing playlist, or would it just have the old version of the playlist?
#174686 - 11/08/2003 13:09 Re: i lost all my music??!!! [Re: image]
frodo_lives
Loc: Fl
i dont have experience with hijak or hyper terminal, so could u please tell me what i need to do? where is the FAQ as to what i need to do?
#174687 - 11/08/2003 13:17 Re: i lost all my music??!!! [Re: frodo_lives]
frodo_lives
Loc: Fl
i ran the search, and nothing poopped up, but only the music that i have just loaded on to it.
#174688 - 11/08/2003 13:24 Re: i lost all my music??!!! [Re: frodo_lives]
If you follow the links I just gave, all of the necessary information is sub-linked from there. Please read through those links VERY carefully and follow their sub-links.
#174689 - 11/08/2003 14:02 Re: i lost all my music??!!! [Re: tfabris]
frodo_lives
Loc: Fl
when i am entering the follwing commands in hyperterminal
rwm
rm /drive0/var/database
rm /drive0/var/database3
rm /drive0/var/tags
rm /drive0/var/playlists
rm /drive1/var/database
rm /drive1/var/database3
rm /drive1/var/tags
rm /drive1/var/playlists
am i supposed to hit enter after each line? thats stupid, bu i did, and i went thru all the commands the FAQ said to do, and nothign happened
#174690 - 11/08/2003 14:04 Re: i lost all my music??!!! [Re: frodo_lives]
Are you running the developer version of the software?
If you are not running the developer version of the software, you won't get a shell prompt when you Q and nothing will happen when you type those commands.
Make absolutely sure to go through every single step listed in the FAQ, from the very top, in exact order. Making sure you were on the developer version was one of the steps.
Did you also rule out disk drive problems before starting that procedure, as was listed in the FAQ?
#174691 - 11/08/2003 14:08 Re: i lost all my music??!!! [Re: tfabris]
frodo_lives
Loc: Fl
ya,
i ruled out that disc problem
and i am running the delepoer version
ill go thru it once more.
thanks for being prompt
#174692 - 11/08/2003 14:12 Re: i lost all my music??!!! [Re: frodo_lives]
So are you getting a shell prompt when you Q?
What EXACTLY does the screen look like when you run through those commands? Copy and paste from Hyperterminal if need be. Also copy and paste the section of the boot log where it detects the disk drives.
#174693 - 11/08/2003 14:56 Re: i lost all my music??!!! [Re: tfabris]
frodo_lives
Loc: Fl
this is what it looks like
empeg-pump v0.03 (19980601)
Mounting proc
Starting player
Restored terminal settings
Abnormal player termination
Player received SIGINT, user interruption
Starting bash.
empeg:/empeg/bin# rwm
EXT2-fs warning: mounting unchecked fs, running e2fsck is recommended
#174694 - 11/08/2003 15:01 Re: i lost all my music??!!! [Re: frodo_lives]
frodo_lives
Loc: Fl
here is some more
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:0f:2
3
Partition check:
Mounting proc
Starting player
Starting bash.
empeg:/empeg/bin# rm /drive0/var/database
empeg:/empeg/bin# rm /drive0/var/database3
rm: cannot remove `/drive0/var/database3': No such file or directory
empeg:/empeg/bin# rm /drive0/var/tags
empeg:/empeg/bin# rm /drive0/var/playlists
empeg:/empeg/bin# rm /drive1/var/database
rm: cannot remove `/drive1/var/database': No such file or directory
empeg:/empeg/bin# rm /drive1/var/database3
rm: cannot remove `/drive1/var/database3': No such file or directory
empeg:/empeg/bin# rm /drive1/var/tags
rm: cannot remove `/drive1/var/tags': No such file or directory
empeg:/empeg/bin# rm /drive1/var/playlists
rm: cannot remove `/drive1/var/playlists': No such file or directory
#174695 - 11/08/2003 15:08 Re: i lost all my music??!!! [Re: frodo_lives]
Okay, it looks like it's doing what it's supposed to be doing for the most part. You are getting both drives detected, the bash prompt is appearing. and the commands are executing as expected.
However, there are two problems I see. Here is problem one:
I don't think it's supposed to exit the player with an error like that. I could be wrong.
This indicates there is something wrong with the file systems. You have ignored the text in that FAQ entry telling you exactly what to do if you get an E2FSCK error message. Please follow those instructions, then repeat the procedure and see if your playlists come back after that.
#174696 - 11/08/2003 16:03 Re: i lost all my music??!!! [Re: tfabris]
frodo_lives
Loc: Fl
i did what you told me to do.
here is what it says
Partition check:
change_root: old root has d_countempeg init 0.8
Mounting proc
Starting player
Starting bash.
empeg:/empeg/bin# ro
empeg:/empeg/bin# umount /dev/hda4
empeg:/empeg/bin# swapon /swapfile
Adding Swap: 16596k swap-space (priority -1)
empeg:/empeg/bin# fsck -fay /
Parallelizing fsck version 1.19 (13-Jul-2000)
e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
hda5 is mounted.
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
/dev/hda5: 1514/4096 files (0.5% non-contiguous), 9457/16384 blocks
empeg:/empeg/bin# fsck -fay /dev/hda4
hda4 is mounted.
/dev/hda4: 87/228288 files (20.7% non-contiguous), 136994/29219400 blocks
empeg:/empeg/bin# fsck -fay /dev/hdc4
hdc4 is mounted.
/dev/hdc4: 69/228288 files (26.1% non-contiguous), 136518/29219400 blocks
empeg:/empeg/bin# swapoff /swapfile
empeg:/empeg/bin# sync
empeg:/empeg/bin#
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg52 (rob@aphex) (gcc version 2.95.3 20010315
(release)) #11 Tue Apr 1 18:49:59 BST 2003
empeg-car player (hardware revision 9, serial number 40103875)
Command line: mem=16m
Buffer cache hash table entri
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: FUJITSU MHL2300AT, ATA DISK drive
hdb: FUJITSU MHL2300AT, ATA DISK drive
hda: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63
hdb: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
smc9194.c:v0.12 03/06/96 by Er
#174697 - 11/08/2003 16:34 Re: i lost all my music??!!! [Re: frodo_lives]
Okay, now try opening it in Emplode and see if your files are there now.
#174698 - 11/08/2003 16:44 Re: i lost all my music??!!! [Re: tfabris]
frodo_lives
Loc: Fl
its not there.
oh well
#174699 - 11/08/2003 16:50 Re: i lost all my music??!!! [Re: frodo_lives]
Try this:
Get to a BASH prompt.
cd /drive0/fids
ls -l
Note, those are Lower-case letter L's there in that last command, not i's.
#174700 - 12/08/2003 09:28 Re: i lost all my music??!!! [Re: tfabris]
frodo_lives
Loc: Fl
its been loading music database all this time since i gave those commands
what do i write in the shell prompt now?
#174701 - 12/08/2003 09:40 Re: i lost all my music??!!! [Re: frodo_lives]
Like I said in the FAQ entry...
If that happens, click here and perform the procedure to manually FSCK the disks. You might need to repeat the above procedure after a manual FSCK.
#174702 - 12/08/2003 09:41 Re: i lost all my music??!!! [Re: frodo_lives]
frodo_lives
Loc: Fl
this is what hyperterminal had on the screen
99040 Aug 12 04:01 e60
-rw-r--r-- 1 0 0 212 Aug 12 04:01 e71
-rw-r--r-- 1 0 0 3016704 Aug 12 04:01 e80
-rw-r--r-- 1 0 0 202 Aug 12 04:01 e91
-rw-r--r-- 1 0 0 5294767 Aug 12 04:01 ea0
-rw-r--r-- 1 0 0 144 Aug 12 04:01 ec1
-rw-r--r-- 1 0 0 3858309 Aug 12 04:01 ed0
-rw-r--r-- 1 0 0 189 Aug 12 04:01 ee1
-rw-r--r-- 1 0 0 4971752 Aug 12 04:02 ef0
-rw-r--r-- 1 0 0 176 Aug 12 04:02 f01
-rw-r--r-- 1 0 0 5628032 Aug 12 04:02 f10
-rw-r--r-- 1 0 0 181 Aug 12 04:02 f41
-rw-r--r-- 1 0 0 2338448 Aug 12 04:02 f50
-rw-r--r-- 1 0 0 214 Aug 12 04:02 f61
-rw-r--r-- 1 0 0 2889769 Aug 12 04:02 f70
-rw-r--r-- 1 0 0 242 Aug 12 18:17 f81
-rw-r--r-- 1 0 0 202 Aug 12 04:02 f91
-rw-r--r-- 1 0 0 3317591 Aug 12 04:02 fa0
-rw-r--r-- 1 0 0 171 Aug 12 04:02 fb1
-rw-r--r-- 1 0 0 3593155 Aug 12 04:02 fc0
-rw-r--r-- 1 0 0 185 Aug 12 04:03 fd1
-rw-r--r-- 1 0 0 3294264 Aug 12 04:03 fe0
-rw-r--r-- 1 0 0 128 Aug 12 04:03 fe1
-rw-r--r-- 1 0 0 3283508 Aug 12 04:03 ff0
empeg:/drive0/fids#
so what do i enter in the prompt now, since its still loading the music database it says. i am gonna step on it. ugghh
#174703 - 12/08/2003 09:44 Re: i lost all my music??!!! [Re: frodo_lives]
Are those the ONLY files in that folder? That's not many, that's only a few songs.
Are you sure you didn't accidentally press delete on the root playlist or something?
#174704 - 12/08/2003 09:50 Re: i lost all my music??!!! [Re: tfabris]
frodo_lives
Loc: Fl
pretty sure. but the player still has on the screen, "loading music database".
do i just shut off power?
#174705 - 12/08/2003 09:56 Re: i lost all my music??!!! [Re: frodo_lives]
but the player still has on the screen, "loading music database". do i just shut off power?
Oh, now I see your question.
Once you drop to the shell prompt, the screen doesn't change. Only the player software changes the screen. What you're seeing is just whatever was on the screen the last time before you got to the shell prompt.
I thought you were saying the player froze on "loading music database" every time you turned on the power. You're just saying that the screen still says it while you're at the shell prompt. That's normal.
When you are done at the shell prompt, type "exit" to get back to the regular software. If you haven't set the drives to read-write, you can also shut off the power if you like.
#174706 - 12/08/2003 09:57 Re: i lost all my music??!!! [Re: tfabris]
frodo_lives
Loc: Fl
thanks tony
#174707 - 12/08/2003 10:35 Re: i lost all my music??!!! [Re: frodo_lives]
frodo_lives
Loc: Fl
tony, i am pretty sure i need a new HD cable. how can i go about getting a nwe one?
#174708 - 12/08/2003 10:49 Re: i lost all my music??!!! [Re: frodo_lives]
I thought you said you ruled that out.
Information on repairing the cable or getting a new one is here.
