#178425 - 09/09/2003 07:08 Is I2S at 1 x fs?
jsuen
I am currently brain-storming a project of interfacing the Empeg player directly to a DAC chip, using the I2S signals and thus bypassing the SPIDF output and digital receiver/filter. The DAC used will accept I2S signals (system clock, word select and data) directly. No oversampling will be used. I would like to know if the I2S signals tapped from the I2S pads are at 1x fs (44.1kHz).
Info on non-oversampling DAC can be obtained in the digital forum of the audioasylum or diyaudio website.
#178426 - 09/09/2003 08:20 Re: Is I2S at 1 x fs? [Re: jsuen]
maczrool
Loc: Louisiana, USA
Yes they are.
Stu
#178427 - 09/09/2003 08:56 Re: Is I2S at 1 x fs? [Re: maczrool]
jsuen
Thanks a lot.
#178428 - 09/09/2003 12:21 Re: Is I2S at 1 x fs? [Re: jsuen]
maczrool
Loc: Louisiana, USA
You're welcome. Be sure to buffer those I2S signals before sending to your DAC. They won't drive cable without it.
Stu
#178429 - 10/09/2003 01:04 Re: Is I2S at 1 x fs? [Re: maczrool]
jsuen
This will be a one-box design. The Empeg player and the DAC will be in the same enclosure. I will keep the signal cables feeding the I2S short.
#178430 - 10/09/2003 18:29 Re: Is I2S at 1 x fs? [Re: jsuen]
maczrool
Loc: Louisiana, USA
That's fine, but even 6 inches is too lonb in my experience. Believe me I know, because I sell the I2S boards in the S/PDIF link above. You WILL need a buffer unless you enjoy listening to continuous dropouts. If you need any help with that let me know.
Stu
#178431 - 11/09/2003 02:25 Re: Is I2S at 1 x fs? [Re: maczrool]
jsuen
Sure. Thanks!
