#178501 - 09/09/2003 14:47 OGG and MP3 Tags
Happy Birthday msandrews
Loc: San Diego, CA, U.S.A.
Hi I am woindering how the karma will handle searching of both ogg and mp3 files at the same time. If I were to search on any number of variables would karma display both ogg and mp3 at the same time or would I have to search seperately? if i didn't know which files were which would I not be able to tell the difference on the karma's interface? How easy is it to setup playlists with both ogg and mp3?
Lets also throw FLAC into the mix for all of the questions above?
- Mike
#178502 - 09/09/2003 15:12 Re: OGG and MP3 Tags [Re: msandrews]
Your question makes no sense when applied to the Karma. The only reason that it cares whether a track is MP3/WMA/Ogg or FLAC is when deciding which codec to process it with.
Otherwise, every type of supported track is treated equivalently.
It would display them at the same time. As explained, it doesn't actually care that one track is MP3 and another is Ogg, until it's time to actually play them.
Why do you particularly care which format your file is? I believe that the track information screen will tell you this information, but Karma doesn't require that you know what format your files are in.
Easy. As I said -- Karma doesn't care what format a file is until it tries to play it.
Makes no difference.
Edited by Roger (09/09/2003 15:16)
#178503 - 09/09/2003 15:24 Re: OGG and MP3 Tags [Re: Roger]
RobotCaleb
wow
never seen so many ways to say the same thing.
#178504 - 10/09/2003 00:10 Re: OGG and MP3 Tags [Re: RobotCaleb]
it seems to me that since mp3 and ogg vorbis have different tagging systems that there might be discrepancies. Since I am not an expert on this subject i was just wondering what those differences might be and how or if that would affect the Karma?
- Mike
#178505 - 10/09/2003 00:41 Re: OGG and MP3 Tags [Re: msandrews]
Ah. The key piece of information you're missing is:
The Cambridge team has always designed their products to work off of their own internal database. Never directly off of the tags.
When you put an MP3 file into any of their products (be it the empeg car, the Karma, the Rio Central, whatever), it only touches the tag the very first time it's dropped into the software (emplode, Rio Music Manager, whatever). It reads the tag just that once, to import the track information into its database.
From that moment on, the player has no concept of tags. The player software itself can't even read the tags. Only Emplode/RMM can read the tags, and only at the initial import time. Everything else except that initial import is done in the database.
The database entry for each song file is the same. The only thing that differs in the database between an Ogg file and an MP3 file is the one flag telling it which audio stream decoder to use when playing it. Everything else that deals with the song file is identical regardless of the file format.
So that's why your question seemed so strange to us. We knew that key tidbit of information (and now you do, too. ).
#178506 - 10/09/2003 05:11 Re: OGG and MP3 Tags [Re: msandrews]
mschrag
Loc: Richmond, VA
RMM/RMML's Order of tag preference (last in list "wins") at import time:
MP3: ID3v1, ID3v2
Ogg: IdentificationHeader
FLAC:Ogg comments, ID3v2
In the case of MP3, I believe they are superimposed -- so ID3v1 gets read in, then ID3v2 is overlayed on top (and duplicates, ID3v2 wins). However, on FLAC, I think if there are ID3v2, it and only it gets used.
For uniqueness calculation:
MP3: After ID3v2 to before ID3v1
Ogg: Entire file
Flac: After ID3v2 to end of file
Other than that, they are treated equally (except obviouslly, the choice of codec for playback on the player)
#178507 - 10/09/2003 05:56 Re: OGG and MP3 Tags [Re: mschrag]
Yes. That's not how it's actually implemented (IIRC), but that's the result.
#178508 - 10/09/2003 11:44 Re: OGG and MP3 Tags [Re: Roger]
Now if only we had a function in emplode to write back the contents of the database to the tags themselves... hint hint.. Yeah, I know you've heard it before (from me no less )
#178509 - 10/09/2003 12:26 Re: OGG and MP3 Tags [Re: hybrid8]
I'm not the one you want to be hassling -- in 9 days time, I'll not be employed by Rio. I'm not sure who you actually want to be hassling, though.
More sensibly, plans for the v3.0 car player software involve making it compatible with Rio Music Manager (which will require changes to RMM as well -- it doesn't currently support heirarchical playlists), which will make this stuff easier in future.
Edited by Roger (10/09/2003 12:29)
#178510 - 10/09/2003 14:02 Re: OGG and MP3 Tags [Re: tfabris]
mwest
Loc: Ada, Oklahoma
Just for clarification... this is the reason that changes made to the "tags" in the music manager do not edit the actual tags and also do not go with the music if exported off an empeg... Correct?
-Michael West
#178511 - 10/09/2003 14:14 Re: OGG and MP3 Tags [Re: Roger]
Sorry to see you go Roger...you've been really great to the empeg community. I'm assuming you'll still be an empeg owner and thus on the forums occasionally?
Out of curiosity, do you have another job lined up yet?
#178512 - 10/09/2003 14:14 Re: OGG and MP3 Tags [Re: mwest]
Correct.
#178513 - 10/09/2003 15:33 Re: OGG and MP3 Tags [Re: tfabris]
thanks tfabris
- Mike
#178514 - 10/09/2003 15:54 Re: OGG and MP3 Tags [Re: msandrews]
jarob10
Loc: Stockport, UK
thanks tfabris
admit it - you preferred the initial response
Edited by jarob10 (10/09/2003 15:56)
#178515 - 10/09/2003 22:11 Re: OGG and MP3 Tags [Re: Roger]
genixia
What are you doing wasting time here then? Get back to work.
#178516 - 11/09/2003 01:14 Re: OGG and MP3 Tags [Re: mwest]
This is the reason that changes made in emplode don't change the actual tags. In Rio Music Manager, changes to files listed in the Media Library are written to the files as well. Using the term "music manager" might be misleading.
#178517 - 11/09/2003 01:15 Re: OGG and MP3 Tags [Re: genixia]
Get back to work.
But I'm not working on emplode, anyway (or RMM2 for that matter), so it wouldn't do you any good .
#178518 - 11/09/2003 01:16 Re: OGG and MP3 Tags [Re: JBjorgen]
No.
#178519 - 11/09/2003 08:21 Re: OGG and MP3 Tags [Re: Roger]
Well, if you want to move to move to the Armpit of America™ (South Carolina) and program for far less than you are currently making, I've got a great job for you at my company
Anyway...good luck finding employment in a rough market.
#178520 - 11/09/2003 08:24 Re: OGG and MP3 Tags [Re: JBjorgen]
<mental picture of Roger working at Billingsgate>
"What sort of muppet landed this cod? The spec clearly says halibut!"
#178521 - 11/09/2003 08:28 Re: OGG and MP3 Tags [Re: peter]
err...maybe that should have read "job market"
#178522 - 11/09/2003 10:58 Re: OGG and MP3 Tags [Re: peter]
ROFLMAO
Roger, I'm sure you will be sorely missed there. That lady in London certainly must be someone very special. I wish you both the very best.
#178523 - 11/09/2003 15:43 Re: OGG and MP3 Tags [Re: tfabris]
Either that, or she's rich...he doesn't seem too concerned about not having a job lined up
