#180654 - 20/10/2003 10:41
Re: 802.11b bridge cheap (Sync your empeg wirelessly)
[Re: drakino]
You can buy direct from Mitsumi for $50.
#180655 - 20/10/2003 12:14
[Re: drakino]
Loc: New Orleans, LA
I wonder how long before the cable company figures out that lots of people are sharing their internet access in an apartment setting. I did that for a while, in effect getting my internet for free, whilst my neighbors payed $15 a piece. MUCH better than the $60 the normally charge.
#180656 - 20/10/2003 12:23
[Re: lectric]
They already know in Manhattan. I remeber there being a lot of news about it a year-or-so ago. This was the only article I could quickly find on google:
http://www.ambriente.com/wifi/anti_wf.html
#180657 - 20/10/2003 12:25
[Re: robricc]
Of course, on the other side of the fence, Speakeasy will handle the billing and let you do the tech support and get free DSL They're so geek-friendly I nearly feel bad for not using them. (Ok, not realy. I'm gratefull to Cyberonic everytime I have to upload something)
#180658 - 20/10/2003 14:50
[Re: lectric]
I honestly don't feel too bad about splitting my internet bill, considering they enjoy raising my rates all the time, due to not also subscribing to their TV service.
#180659 - 20/10/2003 14:54
[Re: drakino]
I'd normally agree, but for some reason Cox brain-farted and gave me a really good deal on my digital cable/Internet/telephone bill. For all 3 services, plus all the HBO's, Showtimes,Cinemax's, and Stars channels I pay 118 a month. I know people that spend that much on regular cale.
I've got this thing about not screwing a company that's not screwing me.
#180660 - 20/10/2003 17:17
[Re: Jerz]
Loc: New Hampshire, USA
I just tried using one as an access point and the other in infrastructure mode. Still nothing.
Doug
#180661 - 20/10/2003 18:47
[Re: phi144]
Loc: Jesusland
Huh...well, I'm no expert, but here is a pic of my access point with the wavit11. I actually have it connected directly to this computer and have it working with my existing access point. Maybe it'll shed some light?
#180662 - 20/10/2003 18:51
[Re: Jerz]
Loc: Jesusland
Here is a shot of the status, properties and encrytion tabs working with my existing accesspoint.
#180663 - 20/10/2003 18:54
[Re: Jerz]
Loc: Jesusland
...and the Evironment and Wireles Bridge tabs...
#180664 - 20/10/2003 19:02
[Re: Jerz]
Loc: Jesusland
Where I went wrong was in the area of SSID. When using two of the wavit11's together they seem to use the serial number of the unit instead of the ssid
I could no longer edit that post but wanted to make it clear that when using the two wavit11's together they use the mac addresses to identify each other (not the serial number as I mistakenly posted).
#180665 - 21/10/2003 05:48
[Re: Jerz]
Jerz,
Thanks for the follow-up. I tried making one watit11 an access point and the other in infrustructure mode. Still nothing. I checked all my settings and they are all compariable to the ones you posted.
Here is how I have it setup. Wireless D-Link router with 4 port switch. Cable modem in the WAN slot. My main compter plugged into one port. wavit11 access point plugged into another port and wavit11 sitting out there wirelessly. I have my SSID setup to be identical for the router and both wavit11's. I'm not currently using encryption.
Do I have something setup wrong at this point? I know it must be something I'm missing. I have no problem connecting wirelessly between my router and laptops although that is different than using the wavit11s.
Your help is appreciated.
Thanks,
Doug
#180666 - 21/10/2003 05:56
[Re: Jerz]
OK, I just saw your post about the wavit11's using the mac address instead on the SSID's. I haven't tried that. Tonight I will try replacing the SSID with the mac addresses. Which mac address are you using? The access point mac address, the infrustructure wavit11's mac addess?
Thanks,
Doug
#180667 - 21/10/2003 17:04
[Re: Jerz]
I give up. Thanks for your suggestions.
Doug
#180668 - 21/10/2003 18:26
[Re: phi144]
Loc: Jesusland
You can't give up THAT easy. Here are some step by step instructions to use with your existing access point.
READ THESE INSTRUCTIONS FIRST BEFORE DISCONNECTNG YOUR COMPUTER FROM YOUR LAN. MAKE SURE OU HAVE ALL INFO IN THESE DIRECTION IN REFERENCE TO YOUR ACCESS POINT BEFORE PROCEEDING. Worst case simply plug your computer back into the hub.
1. Plug the computer you are currently using into the wavit11
2. Start Wavit11 Configuration Tool
3. Click File -> Initialize and Click "OK" to make Wavit11 go back to default setting.
4. Enter the MAC address of the wavit11 connected to your computer. (In my case 20 01 13) The wavit11 will not work if you get this part wrong.
5. Click OK on the window that says the initializtion commant was transmitted.
6. You should now see the mack address and IP address of the wavit11 in the "wavit11 wireless lan" window.
7. Click the IP address button.
8. Enter an IP address within the IP address range of your computer. With windows XP you can right click on the network connection icon in the tray to figure out the address of your computer. In my case my computer ip address is 192.168.1.10 and the subnet mask is 255.255.255.0 so I'll enter 192.168.1.188 (because I know that address is not used on my network but within the range) and 255.255.255.0
9. Click OK once you have the ip address and subnet mask entered.
10. Click OK in the dialog box that says "IP address configuration has completed"
11. Your updated ip address info should now show up in the "Wavit11 wireless lan" window.
12. Note that mode is set to "AdHoc" by default.
13. Highlight the Wavit 11 in that window (it'll be highlighted by default) and click "setup".
14. Click "Property" tab
15. Change "Operation Mode" to "Infrastructure"
16. Change the SSID to your accesspoint SSID (in my case it is 0b964), my channel is set to 1 to agree with my access point. Everything else I'm leaving as default.
17. Click Encryption mode tab and select 40bit WEP or 128bit (whatever your access point is set to) or "disable" if encrtion is not set. Since I have encryption turned on I'll type in me code in ascii format and click "write". My default key is set to "1" (not sure what that is by the way)
18. Click "OK" to the "configuration setting change has completed" window.
19. Click the "Status" tab and you should now see the MAC address along with the SSID of your access point listed.
20. Click the "Environment" tab and you should now see your signal strength.
21. Try to get on the internet. You should now be able to get on and I'm fixin' to post this message since I KNOW these are the EXACT steps to get the wavit11 to work with an existing access point.
Addtional things I'll be doing:
22. Go back to the "wavit11 wireless lan window"
23. click on the wavit 11 listed (it'll be highlighted b default).
24. Click the "IP Address" button.
25. In the IP address configuration window click the "enable" radio button since I have DHCP enabled.
26. OK and OK.
That's it, you should now be able to work with your existing access point.
#180669 - 21/10/2003 19:30
[Re: Jerz]
Loc: Jesusland
TO SET UP A WAVIT11 AS AN ACCESS POINT:
1. Plug the computer you are currently using into the OTHER wavit11.
2. Start the "wavit11 configuration tool"
4. Click "OK" to set the wavit11 to default
5. Enter the MAC address of THIS access point (in my case it is 20 01 16) and click "OK"
6. You should now see the MAC address of the wavit11 in the "wavit11 wireless lan" window.
7. Click "IP address" button
8. Enter an IP address within the range of your lan. In my case it will be 192.168.1.242 with a subnet mask of
255.255.255.0
9. Click "OK"
10. Click "OK" in the "IP Address configuration" dialog box.
11. You should now see the mac and ip address of your wavit 11.
12. Notice that the mode is set to "AdHoc" by default.
13. Click the "setup" button.
14. Click the "Property" tab.
15. Select "access point" as the "operational mode" and click the "apply" button.
16. Click "OK to the "configuration setting change" dialog box.
17. Click "encryption mode" tab and set it to your choice. I will set it to "disable" (default).
It is now setup as an access point. Unplug from the computer and plug into a hub.
Now, I'll plug the wavit11 that I set up to infrastructure mode back into the computer I'm working in now to check the
access point.
1. Quit the configuration tool if you haven't done so already.
2. Start the wavit11 configuration tool.
3. The wavit11 that we previously set up to infrastructure mode should pop right up.
4. Click the "setup" button.
5. Click the "property" tab.
6. Click the "back to default" button, click "apply" and "OK" to the window that pops up.
7. Set the operation mode to "infrastructure" and click "apply" then click "OK" to the dialog box that pops up.
8. Click the "status" tab and you should now see the mac address and ssid (which will be "Wavit11") of your wavit11 access
point.
9. Click the "environment" tab and you should see your signal strength.
10. Try to get on the internet.
11. If it wasn't working, I wouldn't be posting.
#180670 - 21/10/2003 19:51
[Re: phi144]
Loc: Jesusland
Sorry, I didn't mean for you to replace the ssid with the mac address.
Please look at my directions below.... I HOPE this helps... it should, because I took each step.
What is confusing is that apparently the ssid of the wavit11 is "Wavit11" just follow the directions below.
Thanks... we'll get it working and if anyone else wants to jump in please do so... but it's gotta work after this. I basically wiped mine out and started from scratch without a problem.
#180671 - 22/10/2003 08:19
[Re: Jerz]
OK,
I pretty much did what you suggested here but I started over using your instructions just to see if it works.
It's not working. On the status tab nothing is showing in the box in the lower half of the screen.
Very confusing. I agree with you, it should work.
Doug
#180672 - 22/10/2003 08:35
[Re: phi144]
Loc: Jesusland
Hmmmm.... if that doesn't work maybe you have a defective one?
When my existing access point didn't show up after I did the first set of instructions with the wavit11 in infrastructure mode either the ssid, channel or wep code didn't match.
Edited by Jerz (22/10/2003 08:38)
#180673 - 22/10/2003 08:37
[Re: Jerz]
I thought the same, but I have 2 and neither work. I find it hard to believe that I received 2 defective units.
No idea.
Doug
#180674 - 23/10/2003 09:29
[Re: Jerz]
Well, like I said before, I doubt they are defective. It is obviously something wrong on my end. Anyway, I have an alternate solution that doesn't involve going wireless and was wondering if you were interested in buying a couple more. If not I'll just send them back.
Thanks again for all your help.
Doug
