#183762 - 09/10/2003 06:00 ogg content type?
mschrag
Loc: Richmond, VA
So I wrote an app for the Karma to stream music off of it ... It works fine for MP3, but fails for OGG. Is it possible I have the wrong content type? Anyone see anything obviously wack about the header returned when requesting an ogg:
MP3: (works)
GET /streamFile?fid=4336
HTTP/1.1 200 OK
Connection: close
Accept-Ranges: bytes
Content-Length: 4978688
Content-Type: audio/mpeg
Content-Disposition: attachment; filename=Track 4.mp3
...music data...
OGG: (does not work)
GET /streamFile?fid=6256
HTTP/1.1 200 OK
Connection: close
Content-Length: 4915296
Content-Type: application/ogg
Content-Disposition: attachment; filename=track 7.ogg
...music data...
#183763 - 09/10/2003 06:04 Re: ogg content type? [Re: mschrag]
Case sensitivity on the track name? Is the MIME type right: application/ogg?
#183764 - 09/10/2003 06:15 Re: ogg content type? [Re: pgrzelak]
mschrag
Loc: Richmond, VA
application/ogg came from an RFC that I found on ogg ... I noticed that I didn't have a mapping in my registery for that type, though ... I set that up, but still no dice. Maybe I'll hunt around in winamp and see if I can figure out what mime type it expects. Has anyone streamed an ogg in winamp before?
#183765 - 09/10/2003 06:33 Re: ogg content type? [Re: mschrag]
Have't tried it here.
But I would expect application/x-ogg or application/x-vorbis to work.
Speaking of which, on the player, what is the tag type for an ogg? Is it "ogg", or "vorbis" (in the tag file). I want to add three lines to Hijack's webserver for them.
#183766 - 09/10/2003 06:54 Re: ogg content type? [Re: mlord]
Oopps..
I meant to say: audio/x-ogg would be the most correct content-type (mime) for ogg files.
#183767 - 09/10/2003 06:55 Re: ogg content type? [Re: mlord]
#183768 - 09/10/2003 07:05 Re: ogg content type? [Re: mlord]
mschrag
Loc: Richmond, VA
On the Karma, codec=vorbis . I could have sworn it used to be codec=ogg, but that's not true currently. I assume the Empeg is the same.
ms
#183769 - 09/10/2003 07:10 Re: ogg content type? [Re: mlord]
mschrag
Loc: Richmond, VA
Cool -- I'll try these out and see which one is the most successful.
Incidentally, application/ogg may be technically correct, but it certainly SEEMS wrong to me... audio/ogg seems more appropriate. but oh well.
#183770 - 09/10/2003 07:27 Re: ogg content type? [Re: mschrag]
But the Ogg container could in theory contain a Theora video file rather than a Vorbis audio file. Only a, er, application would be able to tell...
#183771 - 09/10/2003 07:33 Re: ogg content type? [Re: mschrag]
Yeah.
Note that application/ogg is brand spanking new, and probably not supported yet by many (most?) players out there. I think audio/x-ogg is probably the most common. The x- part means "use an external player rather than the built-in browser support, if any" (I think).
From grepping through the v3a3 player binary, it appears that vorbis is indeed the tag type on the Empeg as well.
#183772 - 09/10/2003 07:37 Re: ogg content type? [Re: peter]
mschrag
Loc: Richmond, VA
Ah ha. Of course
