#188570 - 07/11/2003 12:57 laptop gutting
thinfourth2
before me sits a very nervous looking laptop
The reason it is nervous is after i robbed it of its hard drive and replaced it with a smaller one is the next thing is its screen is busted and a good friend wants a computer.
I plan on removing the top bit and binning it but i have been told that taking the cable for the display out gives some laptops serious not happy issues.
model is an IBM 390X
anyne know if i can kill the cable or is it duct tape time
#188571 - 07/11/2003 15:57 Re: laptop gutting [Re: thinfourth2]
From the little resarch I was able to do when I was seriously contemplating building a revolutionary new in-car computer to play MP3 files (Than God Hugo came along when he did and saved me from such utter madness!!) I think you will have considerable difficulty with this.
It is no trivial task mating a laptop computer to any display other than the one the manufacturer equipped it with, unless you actually have a video-out port on the computer itself. (I don't even know if any laptops actually have that...)
#188572 - 07/11/2003 16:12 Re: laptop gutting [Re: tanstaafl.]
Actually, all of them do.
His concern is whether removing the LCD display will make the laptop unhappy, or will it boot normally and allow the VGA port to be used?
#188573 - 07/11/2003 16:28 Re: laptop gutting [Re: tfabris]
I've tried it before on a very old Zenith 386 notebook and it booted fine. It should work but the best thing to do is just try it.
#188574 - 08/11/2003 21:33 Re: laptop gutting [Re: tman]
The only problem I can think of is that, as a power savings, the external vid port might be shut off in the bios. On the other hand many laptops have [fn]function keys that switch the external port on, even if it's initially off.
#188575 - 09/11/2003 15:50 Re: laptop gutting [Re: gbeer]
qbasic309
it should work fine. I have a thinkpad 600E that I removed
the LCD from and just used it on an external monitor.
Just try it. Should be ok.
