Page 2 of 2 < 1 2
#18888 - 07/10/2000 12:48 USB [Re: davec]
avatarTX
Loc: Dallas Texas USA
Well, I finally gave up on getting ethernet to work for me. It is some sort of configuration problem with my particular PC, no fault of empeg's. The player is doing its part but I just cannot get my PC to see it.
I went out and bought a bottom of the line USB PCI card and installed it. Now I am transfering files like mad, first try.
I recommend that if anyone behind me is having problems with getting their ethernet to work, USB seems the be a very reasonable answer. Good transfer speed, and no headaches of configuration.
Carl
080000506 12gb-green
Carl Aydelotte Dallas Texas USA empeg MKII 080000506 40gb-green
#18889 - 09/10/2000 08:21 Re: Connecting via ethernet (help) [Re: tfabris]
Verteggio
Loc: Atlanta, GA USA
An update ---
I installed 1.01 release over the weekend, and still have the same situation. Emplode is finding two instances of the empeg, both on the same IP address. As well, this happens on both DHCP and direct IP configuration, and it finds the correct ip address both times (twice )..
Although this does not bother me or cause any problems at all, thought I would just bring it up to see if I am the only one or if there are others. If any of the empeg people have time and want to troubleshoot this, since it might affect others, just send me an email and I would be happy to give some more info on my setup..
--verteggio
#18890 - 09/10/2000 08:28 Re: Connecting via ethernet (help) [Re: Verteggio]
Version 1.1 is completely rewritten in this area, so there's little usefulness in diagnosing a problem with v1.01, unless it's causing serious difficulty.
#18891 - 09/10/2000 08:45 Re: Connecting via ethernet (help) [Re: tfabris]
and ethernet isn't that much faster
Yet.
#18892 - 09/10/2000 08:56 Re: Connecting via ethernet (help) [Re: peter]
EngelenH
Loc: Belgium/Holland
Don't you just hate when they do that ...
Hans
Mk2 - Blue - 080000431
Mk2 This message will selfdestruct in 5 seconds to prevent reproduction.
Page 2 of 2 < 1 2
