#189557 - 14/11/2003 21:04 Aux input question
djdrock
I am going to have installed my 2nd empeg into my 93 MR2, but want to have a CD player (for tuner purposes mostly) installed. It is a double din factory stereo. Is this a fairly simple process as far as the wiring goes. Would the alpine simply plug into the aux inputs if the empeg? Thanks!
1993 MR2 MK2a 32gb. 1991 NSX unfortunately with and IPOD.
#189558 - 14/11/2003 21:16 Re: Aux input question [Re: djdrock]
DeadFire
The Alpine CD Receiver is quite likely to have two pairs of preouts - one for the front and one for the rear. Also, depending on the model, you may be able to disable the Alpine's internal amplifier (if it has one), in order to have cleaner sound come from the preouts (or so they say).
I would simply connect the front pair of preouts from the Alpine into the AUX in pair of the empeg. I am using the same method to run my empeg through my Kenwood headunit, since I don't currently have an external amplifier.
#189559 - 18/11/2003 12:23 Re: Aux input question [Re: djdrock]
Djdrock, please read this FAQ entry.
