#190189 - 19/11/2003 23:09 error message
poochieone
hello,
i got my player to work (the power adapor was bad and radioshack had a pretty good new one for me! )
I'm trying to complete my had drive upgrade but my hard (brand new one, just replaced) seems not to be detected as the player gives me the no harddrive found contact support message. i've read te FAQ but to no clear solution based on my knowledge.
the message i get from hypertermnal is the following:
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:06:4
b
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...Kernel panic: VFS: Unable to mount root fs on 03:05
what does this mean and how do i fix it?
please help,
Marco
#190190 - 20/11/2003 02:56 Re: error message [Re: poochieone]
thinfourth2
1 have you applied the builder image to the empeg with the new drive in it
2 you putting in an new drive and removing old one or adding a extra drive
3 post the whole output from the empeg from the moment you power it up as before that it tries to find the disc
4 Where are you incase we need to roll out internaional rescue
#190191 - 20/11/2003 17:18 Re: error message [Re: thinfourth2]
poochieone
i'm replacing the disk with a 40 gig.
i tried loading the builder but i'm not sure if it completed because it wouldn't complete the 'finding pump' type message ... basically i don't thjnk it ever shut down and restarted as per the upgrade instructions say it would. however, i have the newest emptool updated..
heres the complete output from the time i turn on the player:
˙If there is anyone present who wants to upgrade the flash, let them speak now,
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.14-rmk5-np17-empeg51 (mac@aphex) (gcc version 2.95.3 20010315 (release)) #16 Wed Jul 24 18:19:54 BST 2002
empeg-car player (hardware revision 9, serial number 10101611)
Command line: mem=16m
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005f00).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:06:4b
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
Press Ctrl-A to enter pump... Kernel panic: VFS: Unable to mount root fs on 03:05
thanks for the help,
Marco
#190192 - 20/11/2003 17:37 Re: error message [Re: poochieone]
Greetings!
It never located the hard drive. Please check the cable connection and reconnect it if it is loose. Thanks!
#190193 - 20/11/2003 23:22 Re: error message [Re: pgrzelak]
poochieone
hi,
thanks for the hints guys!
no matter what i do with the cable, nothing happens. i've checked the jumpers and they are all good. i guess this means i should be looking or a new cable. where is a good place to find them? or are they only available from support?
thanks,
Marco
#190194 - 20/11/2003 23:39 Re: error message [Re: poochieone]
Please go here and read carefully every single item and check visually everything that is pictured.
#190195 - 21/11/2003 12:36 Re: error message [Re: poochieone]
mtempsch
For debugging purposes a standard laptop drive cable should do, but it is likely to be of the wrong total length, connector spacing and orientation for proper usage in the empeg.
I think support (Rob) is the sole source of proper cables -- unless someone has a spare they're willing to part with. You could buy wire and connectors and build/press a properly configured cable yourself, but without the proper crimp tool it can be hard...
#190196 - 21/11/2003 15:48 Re: error message [Re: mtempsch]
schofiel
I will be able to supply these again in the New Year (see the recent post in Announcements).
I have the feeling there's going to be quite a rush at the start of January. Please note that there is a queue of people who have already asked over the last couple of months while I have been having problems: they MUST be served first, and I hope you all understand this. The best advice I can give is to send an email with your order to me at [email protected] so that I have it here in the queue, and you will get a notice from me in due course when I can go active again with trading. Call it a "late" Christmas present, if you like. Well, actually, call it whatever you want - I don't mind, to be honest
#190197 - 21/11/2003 15:56 Re: error message [Re: schofiel]
Anonymous
Unregistered
dank jij
#190198 - 21/11/2003 16:01 Re: error message [Re: ]
schofiel
Graag gedaan, jongen....
.... but don't forget I'm actually English. I am flattered, sir!
#190199 - 22/11/2003 16:15 Re: error message [Re: poochieone]
poochieone
actually, i managed (with your help) to get everything working now... it's quite a relief!
now the hardest thing is to wait to load my 30 gigs into that drive... yummmm.... cant wait!!
thanks people!!
