Well, I've spent the better part of 2 days trying to figure out my issues, and I have been unsucessful. My empeg seems to play fine, but I can not upload new songs to it without it getting all screwed up. I have checked for hardware problems because I have been having the "checking integrity" issue, I have also tried to check the disks by hand through hyperterminal. I have downgraded to v1.03 and back to v2.00 and performed syncs with both. Sometimes the sync will take a normal amount of time and sometimes it will "rebuild database" all day, among other errors.
Here is the latest output of hyperterminal: (it's really long and it seems like there are tons of errors)
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004300).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DARA-212000, ATA DISK drive
hdb: IBM-DJSA-220, ATA DISK drive
hda: IBM-DARA-212000, 11513MB w/418kB Cache, CHS=23392/16/63
hdb: IBM-DJSA-220, 19077MB w/1874kB Cache, CHS=38760/16/63
smc chip id/revision 0x3349
smc9194.c:v0.12 03/06/96 by Erik Stahlman (
[email protected])
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:12:03:d
7
Partition check:
VFS: Mounted root (ext2 filesystem) readonly.
Freeing unused kernel memory: 4k init
empeg init 0.8
Mounting proc
Press 'q' now to go into development mode. You Have Zero Seconds To Compl Starti
ng player
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
! tags.cpp : 61:Failed to open tags (0xc0041002).
Vcb: 0x4054d000
empeg-car bootstrap v1.00 20000601 (
[email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v347 (root@ibbm) (gcc version 2.95
.3 20010315 (release)) #2 Sun Nov 23 12:29:03 EST 2003
empeg-car player (hardware revision 7, serial number 90000983)
Command line: mem=12m
Memory: 10960k/12M available (980k code, 20k reserved, 324k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Tuner: loopback=0, ID=-1
Scheduling custom logo.
empeg display initialised.
empeg state support initialised 0089/88c1 (save to d0004400).
[email protected])
7
Partition check:
empeg-pump v0.03 (19980601)
Mounting proc
Starting player
Vcb: 0x4054d000
q
@`Restored terminal settings
Player exited normally: 0
Starting bash.
empeg:/empeg/bin# ro
empeg:/empeg/bin# umount /dev/hda4
empeg:/empeg/bin# umount /dev/hdc4
empeg:/empeg/bin# swapon /swapfile
Adding Swap: 16596k swap-space (priority -1)
empeg:/empeg/bin# fsck -fay /
Parallelizing fsck version 1.19 (13-Jul-2000)
e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
hda5 is mounted.
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
/dev/hda5: 1514/4096 files (0.5% non-contiguous), 9457/16384 blocks
empeg:/empeg/bin# fsck -fay /dev/hda4
hda4 is mounted.
/dev/hda4: 3272/92160 files (7.5% non-contiguous), 2816064/2926602 blocks
empeg:/empeg/bin# fsck -fay /dev/hdc4
hdc4 is mounted.
/dev/hdc4: 5896/152576 files (6.8% non-contiguous), 4369839/4862970 blocks
empeg:/empeg/bin# swapoff /swapfile
empeg:/empeg/bin# sync
empeg:/empeg/bin#
[email protected])
e000 v1.04
Copying kernel...
l.
empeg state support initialised 0089/88c1 (save to d0004480).
[email protected])
7
Partition check:
%她չссrrrokay
Mounting proc
Starting player
Vcb: 0x4054d000
hda4 is mounted.
hdc4 is mounted.
Restart code received
Starting player
Vcb: 0x4054d000
Adding Swap: 16596k swap-space (priority -2)
hda4 is mounted.
hdc4 is mounted.
hdb: irq timeout: status=0xd0
ide0: reset timed-out, status=0x80
hda: status timeout: status=0x80
hda: drive not ready for command
hdb: status timeout: status=0x80
hdb: drive not ready for command
end_request: I/O error, dev 03:44 (hdb), sector 18160512
end_request: I/O error, dev 03:05 (hda), sector 22700
ide0: reset: success
hdb: status timeout: status=0xd0
VM: do_try_to_free_pages failed for player...
end_request: I/O error, dev 03:44 (hdb), sector 15
end_request: I/O error, dev 03:06 (hda), sector 272
player(40): memory violation at pc=0x0207f944, lr=0x0207f92c (bad address=0xa7d2
7622, code 2)
pc : [<0207f944>] lr : [<0207f92c>]
sp : bdfffc98 ip : bdfffc98 fp : bdfffcb8
r10: 02153ef4 r9 : bdfffd0c r8 : bdfffd20
r7 : bdfffd1c r6 : 02153e18 r5 : 02162540 r4 : a7d2761a
r3 : 02150948 r2 : bdfffc80 r1 : 00000000 r0 : 00000000
Flags: NzCv IRQs on FIQs on Mode USER_32 Segment user
Control: D035917D Table: D035917D DAC: 00000015
Function entered at [<0207f908>] from [<0207f9cc>]
r5 = 02162540 r4 = 02162540
Function entered at [<0207f994>] from [<02049244>]
r4 = 02153E18
Function entered at [<02049230>] from [<02066da0>]
r5 = 02153EF4 r4 = 02153E18
Function entered at [<02066d84>] from [<020670cc>]
r4 = 00000000
Function entered at [<02066e90>] from [<02066de8>]
r10 = 020AD438 r9 = 02153E18 r8 = 0000340E r7 = 00000080
r6 = 0000000E r5 = 02153E18 r4 = BDFFFD64
Function entered at [<02066dd8>] from [<020ad4f0>]
Function entered at [<020ad438>] from [<020b4824>]
r5 = 02153E30 r4 = BDFFFE40
Function entered at [<020b475c>] from [<020e9bbc>]
r4 = 00000000
Function entered at [<020e8330>] from [<020b45a0>]
r8 = 021573E4 r7 = 021573D0 r6 = 020AD438 r5 = 00000007
r4 = 00000000
Function entered at [<020b44f0>] from [<020e9bbc>]
r5 = 00000000 r4 = 00000000
Function entered at [<bffffcbc>] from [<021c68f0>]
Abnormal player termination
Player received signal 11
Starting player
Vcb: 0x4054d000
F @Restored terminal settings
Starting player
Vcb: 0x4054d000
[email protected])
On DC power, quick boot
e000 v1.04
Copying kernel...
l.
Command line: mem=12m noinitrd
empeg state support initialised 0089/88c1 (save to d0004500).
[email protected])
7
Partition check:
empeg init 0.8
Mounting proc
Starting player
Vcb: 0x4054d000
Like I said, I've tried to do this myself, for fear that it's an issue that has happened to people many times before, but for whatever reason, I can't make it happen.
Most recently, after Emplode had performed a sucessful sync, I tried to upload some tunes and got this error:
0xC004101E is "Read-only file system" (Player error)
as well as this one:
0x8004003E is "Unknown error" (Emplode error)
thanks for the help.
