#194361 - 20/12/2003 02:24 "no AF information available" opposed to my visual
leftyfb
Loc: Lowell, MA
Scold me if I failed at finding this topic already discussed using the search of FAQ. I don't care if RDS or AF works ... I just want my visuals to work when i'm listening to the radio. They worked before 2.00 final, but not after. I tried turning AF and TA off but it does no good. The only visual that does not show "no AF information available" is the radio info which isn't even a visual.
Mk2a 30GB Blue. Serial 030102999
#194362 - 20/12/2003 12:00 Re: "no AF information available" opposed to my visual [Re: leftyfb]
The AF debugger screen is simply one of the info screen choices, along with "Info:Radio", "Info:Line", "Info:Off", etc. Simply select the desired info screen.
#194363 - 21/12/2003 09:14 Re: "no AF information available" opposed to my visual [Re: tfabris]
leftyfb
Loc: Lowell, MA
I'm not talking about info screens, i'm talking the visualizations, like funnelweb. These do not go on when i select them when listening to the tuner. Only the "no AF information available" shows. I can however view them when listening to the player, just not the tuner.
#194364 - 21/12/2003 11:02 Re: "no AF information available" opposed to my visual [Re: leftyfb]
Yes, I know. This behavior is exactly the same whether you are in player mode or in radio mode. If you are on an info screen, you can't see the visuals when you change them. Because it's on an info screen rather than a visual screen.
So please do exactly what I said and it will work: select a different info screen. Select either Info:Line, Info:Transient, or Info:Off and you will then be able to see your visuals.
