#19706 - 07/10/2000 12:43 Sync errors again
I'm having problems with syncs, they fail with "stage 5, 0x80070017 CRC error". I can transfer chunks of data up to about 70Mb at a time, but once it gets beyond that it starts slowing down and eventually fails.
I haven't done may uploads recently, the last time I did a large amount was probably before 1.0, at that point things were rock solid.
When the data starts (or on smaller chunks) it flies at 330kB/s, this is the fastest I have ever seen it...
Setup:
-Mark1 (serial number 47
-Win2k (no service pack)
-USB
-1.01 developer
(large log file posted to [email protected])
__
#19707 - 16/11/2000 06:31 Re: Sync errors again [Re: andy]
Squid2k1
Loc: Ocean Floor
You are not alone, my brudder. I setup a network at home and get Stage 5 0xffffffff synch errors after about 70mb. However, it works at my workplace transferring 650MB at a time. The only difference is the PC. Both run Win2k but one is a Dell and the other is homemade but more powerful/more RAM, etc. i sent a report to EMPEG but have yet to get any sort of feedback. maybe i will send it to support.
Squid2k1
18GB of Green Mk II Fury - Fast As A Shark
Squid2k1 --- 18GB of revived Green Mk II Fury - Fast As A Shark
#19708 - 16/11/2000 07:49 Re: Sync errors again [Re: Squid2k1]
Both of these sound like the problem that Tanstaafl was having a while back. Doug... Thoughts?
#19709 - 16/11/2000 13:06 Re: Sync errors again [Re: tfabris]
...and get Stage 5 0xffffffff synch errors...
No, not the same thing, Tony. My problem (along with more than a dozen other people) was that during the upload emplode would just lock up, almost always during the brief "Preparing to upload file" (or something like that) display between each file. After 3--5 minutes, the empeg would time out and say "End of Playlist" and I would have to reboot the PC before emplode could be run again.
Software version 1.01 cured this problem almost entirely -- instead of lockups two out of three times, I now only lock up maybe once out of ten times. This problem strikes only a small minority of users, and may be related to IRQ conflicts. I'm working on that aspect of it now.
#19710 - 20/11/2000 08:45 Re: Sync errors again [Re: tfabris]
Squid2k1
Loc: Ocean Floor
What exactly is a Stage 5 0xffffffff error???
Squid2k1
#19711 - 20/11/2000 10:06 Re: Sync errors again [Re: Squid2k1]
The 0xffffffff is -1, which is generally a catch-all error number -- i.e. it doesn't mean anything other than "something went wrong".
Stage 5, on the other hand, is the stage in which the bulk of the upload happens.
In short it's saying: "Uploading your changes failed with an unknown error".
Which isn't terribly useful, which is why we're putting quite a lot of work into v1.1 to make the error messages more understandable.
