#202778 - 06/02/2004 13:12 Help! Disk Integrity check error!
russmeister
Loc: South Carolina
I tried to upload a new playlist to my player today and emplode errored out at the disk integrity check. I have since lost all the playlists on the player and the only thing I can play is the aux input. I've already tried this but it didn't work. Maybe I'm doing something wrong.
Here's a copy of the hyperterminal text and I have bolded the things that I see wrong but I don't know what to do about them:
˙If there is anyone present who wants to upgrade the flash, let them speak now,
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v340 (root@ibbm) (gcc version 2.95
.3 20010315 (release)) #2 Wed Jun 18 18:40:14 EDT 2003
empeg-car player (hardware revision 9, serial number 10101463)
Command line: mem=16m
Memory: 15016k/16M available (976k code, 20k reserved, 368k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Tuner: loopback=0, ID=-1
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004900).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hdb: IBM-DJSA-210, ATA DISK drive
hda: IBM-DJSA-220, ATA DISK drive
hda: IBM-DJSA-220, 19077MB w/1874kB Cache, CHS=38760/16/63
hdb: IBM-DJSA-210, 9590MB w/384kB Cache, CHS=19485/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:05:b
7
Partition check:
hdb: [PTBL] [1222/255/63] hdb1 < hdb5 hdb6 > hdb2 hdb3 hdb4
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...hange_root: old root has d_count=1
okay
Mounting proc
Starting player
hijack_exec("/bin/bash -c "/usr/local/bin/start_empire 10 &""), rc=0 (okay)
start_empire: sleeping for 10 seconds...
hijack_exec("/usr/local/bin/telnetd"), rc=0 (okay)
hijack: removed menu entry: "Tuner RDS Control"
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
! tunedb_disk.cpp :1274:Database size mismatch error.
Vcb: 0x4086d000
start_empire: Starting Empire...
IrDA: Registered device irda0
Russ
"The difference between a successful person and others is not a lack of strength, not a lack of knowledge, but rather a lack of will." Vince Lombardi
#202779 - 06/02/2004 13:28 Re: Help! Disk Integrity check error! [Re: russmeister]
Greetings!
It is likely that you have a corrupt or missing database file, as seen in your "Database size mismatch error". Go into the player, delete the existing database files and resync.
#202780 - 06/02/2004 13:30 Re: Help! Disk Integrity check error! [Re: russmeister]
This means that the time since the last FS check has been exceeded. It's harmless.
This error is normal. The car player partitions are ext2 so it will always fail to mount as ReiserFS.
You tried deleting the database from the empeg and getting emplode to recreate it?
#202781 - 06/02/2004 13:34 Re: Help! Disk Integrity check error! [Re: russmeister]
Instructions for database rebuilding are here, but I would be concerned with why the databases need to be rebuilt.
#202782 - 06/02/2004 13:37 Re: Help! Disk Integrity check error! [Re: tfabris]
Greetings!
It errored out as part of a standard sync, according to the post. It is likely, looking at the boot log, that one of the programs (empire, telnetd) had a file open on a drive that was targeted for FSCK.
Wow. I do not envy the admins that are moderating these posts!!! They must be coming in pretty fast!
#202783 - 06/02/2004 13:39 Re: Help! Disk Integrity check error! [Re: pgrzelak]
russmeister
Loc: South Carolina
Call me dumb, but how do I do this through the hyperterminal?
Russ
#202784 - 06/02/2004 13:43 Re: Help! Disk Integrity check error! [Re: russmeister]
Don't. According to what Paul just said, you need to remove/disable Empire and Telnetd and re-FSCK before doing the database rebuild. Only after that should you rebuild the databases. As it says in the FAQ entry here, don't try to FSCK or synch with things like that running live.
#202785 - 06/02/2004 13:43 Re: Help! Disk Integrity check error! [Re: russmeister]
Greetings!
I modified the post with a link to the FAQ entry.
#202786 - 06/02/2004 14:54 Re: Help! Disk Integrity check error! [Re: tfabris]
russmeister
Loc: South Carolina
How do I do this? I can't use config.ini from emplode b/c it won't resync and I'm familiar with linux enough to know how to do this. Any advice?
edit: that was suppose to be that I'm NOT familiar enough with linux but the instructions you linked were easy to follow, Tony.
It still won't rebuild the database in emplode nor does it rebuild after deleting the config.ini and then trying to rebuild it manually.
Edited by Russmeister (06/02/2004 16:07)
Russ
#202787 - 06/02/2004 14:59 Re: Help! Disk Integrity check error! [Re: russmeister]
Delete the config.ini file and start over from scratch, then, as described here.
#202788 - 06/02/2004 16:29 Re: Help! Disk Integrity check error! [Re: tfabris]
russmeister
Loc: South Carolina
Well, I'm off for the weekend. It looks like I'm stuck with the radio until Monday. I'll check back then.
Thanks for the help!
Russ
#202789 - 09/02/2004 15:43 Re: Help! Disk Integrity check error! [Re: russmeister]
I'm checking on Russmeister's player
There are/were some serious issues.
the fids folder on drive0 was missing, and in its place was a file called fids that contained track info for a single song.
I deleted the file and re-created the fids folder and then ran an fsck.
It found a ton of problems and fixed them.
There is still nothing in the fids folder, however, the lost+found folder is populated with a ton of entries, the last few look something like this:
-rw-r--r-- 1 0 0 146 Apr 16 2003 #9989
-rw-r--r-- 1 0 0 4191911 Apr 16 2003 #9990
-rw-r--r-- 1 0 0 177 Apr 16 2003 #9991
-rw-r--r-- 1 0 0 3515522 Apr 16 2003 #9992
-rw-r--r-- 1 0 0 193 Apr 16 2003 #9993
-rw-r--r-- 1 0 0 4083051 Apr 16 2003 #9994
-rw-r--r-- 1 0 0 146 Apr 16 2003 #9995
-rw-r--r-- 1 0 0 3885352 Apr 16 2003 #9996
-rw-r--r-- 1 0 0 142 Apr 16 2003 #9997
-rw-r--r-- 1 0 0 4281260 Apr 16 2003 #9998
-rw-r--r-- 1 0 0 233 Apr 16 2003 #9999
drwxr-xr-x 2 0 0 65536 Feb 3 2001 .
drwxr-xr-x 6 0 0 4096 Aug 9 14:58 ..
If I'm thinking correctly, these are his old song right? Is there any way to recover them, or did I already hose myself by deleting and re-creating the fids folder?
#202790 - 09/02/2004 16:04 Re: Help! Disk Integrity check error! [Re: JBjorgen]
The big ones are tunes, but you'd have to rename and resort them properly, and recreate the various playlists. Messy, very messy.
If the files are available on a PC somewhere, then just nuke the contents of lost+found and reload the music.
#202791 - 09/02/2004 16:17 Re: Help! Disk Integrity check error! [Re: mlord]
Thanks...That's what I needed to know.
#202792 - 09/02/2004 16:26 Re: Help! Disk Integrity check error! [Re: mlord]
Ok. Uploading tunes now. I'm still getting this message in HT though:
e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
ext2fs_check_if_mount: No such file or directory while determining whether /dev/hda4 is mounted.
#202793 - 09/02/2004 17:57 Re: Help! Disk Integrity check error! [Re: JBjorgen]
That message is normal.
EDIT: oopps.. I take that back. I dunno.
Edited by mlord (09/02/2004 17:58)
#202794 - 09/02/2004 18:30 Re: Help! Disk Integrity check error! [Re: mlord]
SE_Sport_Driver
#202795 - 10/02/2004 02:11 Re: Help! Disk Integrity check error! [Re: JBjorgen]
It's complaining about the fact that /etc/mtab is missing. You can ignore it.
#202796 - 10/02/2004 09:11 Re: Help! Disk Integrity check error! [Re: Roger]
Cool. Left it going overnight and it now has roughly 16 gig of music on it and more uploading. Seems to be working great.
I think we can say 'case closed'.
#202797 - 10/02/2004 09:23 Re: Help! Disk Integrity check error! [Re: JBjorgen]
russmeister
Loc: South Carolina
For a minute there I thought I had a really expensive aux input.
Nice to know that's not the case.
Russ
