#205007 - 16/02/2004 20:48 Can't sync with 2.00 final
jbradshw
Loc: Atlanta, GA
Well I was going to upgrade to v3.00 a7 and I read to do a full sync before doing so and then I ran into this problem:
I do a sync in jemplode and everything seems to be fine, but what I noticed is when I editted the config.ini (before syncing), it wasn't saving with the sync so I knew it wasn't syncing right. So... I popped open hyperterminal and captured the log here:
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v374 (root@ibbm) (gcc version 2.95.3 20010315 (release)) #2 Fri Feb 13 16:27:58 EST 2004
empeg-car player (hardware revision 9, serial number 30103111)
Command line: mem=16m
Memory: 15016k/16M available (980k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
Found custom animation at offset 0x9a38c
Tuner: loopback=0, ID=-1
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004800).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hdb: FUJITSU MHL2300AT, ATA DISK drive
hda: FUJITSU MHL2300AT, ATA DISK drive
hda: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63
hdb: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0c:27
Partition check:
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
empeg-pump v0.03 (19980601)
Freeing unused kernel memory: 4k init
empeg init 0.8
Mounting proc
Starting player
hijack_exec("", "exec /usr/local/bin/empacman"), rc=0 (okay)
empacman running as pid 11
emptris v1.3 starting...
hijack_exec("", "exec /usr/local/bin/emptris"), rc=0 (okay)
hijack_exec("", "exec /usr/local/bin/telnetd"), rc=0 (okay)
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
Using non-standard cache size 86 (adjustment 48)
Vcb: 0x4056d000
Doing a sync in Jemplode just gives this:
Adding Swap: 16596k swap-space (priority -1)
e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
(reboot)
Now I tried to manually do the sync using this procedure from the FAQ:
ro
umount /dev/hda4
umount /dev/hdc4
swapon /swapfile
fsck -fay /
fsck -fay /dev/hda4
fsck -fay /dev/hdc4
swapoff /swapfile
sync
But when I do the 'ro' command I get this error:
"mount: can't find /drive1 in /etc/fstab or /etc/mtab"
so I tried to do the next command, and got:
"umount: /dev/hda4: device is busy"
Right now my player is paused so I don't know why it could be "busy".
What do I need to do to remedy this? I planned on getting rid of the emptris, empacman stuff at the end and only leave emphatic but I can't get the changes to save to the player.
One of the last MK2's from SonicBlue... Blue/60gig S/N: 030103111
#205008 - 16/02/2004 23:20 Re: Can't sync with 2.00 final [Re: jbradshw]
The player is trying to do a (media) filesystem check. This will take from 2 minutes to over an hour, depending how much stuff is loaded on the drives. Be patient. VERY VERY patient. Let it do its thing.
#205009 - 16/02/2004 23:38 Re: Can't sync with 2.00 final [Re: mlord]
SE_Sport_Driver
Looking at the log, it looks like you have two 30GB drives, so take Mark's advice and go watch a movie or something.
#205010 - 17/02/2004 00:18 Re: Can't sync with 2.00 final [Re: jbradshw]
elperepat
Loc: Qc, Canada
I don't see emphatic in the log, but you tell you think of "only leaving emphatic". If it's installed and running, you need to "Quit" emphatic by using its menu and THEN, do a sync. You can't upload songs to the player when emphatic is running.
I don't know if other users noticed this, but I need to do so... Took a long time to find what was going on.
Hope this helps
Patrick
#205011 - 17/02/2004 09:01 Re: Can't sync with 2.00 final [Re: elperepat]
jbradshw
Loc: Atlanta, GA
OK I wasn't sure if that was the reason or not.. that's cool. I'll just wait. BTW, how will I know when it's finished?
Oh and I have emphatic running with the @DC command so it won't show up right now.
#205012 - 17/02/2004 20:47 Re: Can't sync with 2.00 final [Re: jbradshw]
newguy1
Loc: Massachusetts,USA
Off Topic question for jbradshw,Your signature says
Blue/60gig
S/N: 030103111
I have a player with the serial number a few numbers higher than yours but my player is a Rio which I thought was a MK2a.So does yours say Rio or Empeg?
MIKE 80Gb RIO
#205013 - 18/02/2004 12:34 Re: Can't sync with 2.00 final [Re: newguy1]
jbradshw
Loc: Atlanta, GA
Yeah it's an MK2a so I'm pretty sure it says RIO on it. When I made that sig I wasn't aware of the MK2/MK2a difference.
