One thing that I had about empeg installs is the number of wires coming out of the unit which I just don't need. I my car I run the device as an aux-in to another head unit, so I only need power, aux-in, and front-out connected. With the standard harness this means that I need to find space behind the dash for hiding the serial, tuner, and rear-out connectors and wires.
Is the connector on the sled available anywhere? This would allow me to make a new simpler harness. Otherwise how hard is it to remove single pins from the stock connector? This would allow me to remove the ones that I'm not using, but put them back later if I sold the unit or wanted to use them.
I might be purchasing another one and doing an install into my wife's car, plus I want to redo the installation into my car, so it would be nice to clean this stuff up. Both are Mk4/A4 VWs with double din dash openings.
alex
