#206956 - 26/02/2004 03:16 My clock runs really Fast
tang_316
Loc: Los Angeles, CA USA
Hello, I just wanted to know if there is a solution for a fast running clock on a riocar. Since I got the unit installed about 2 1/2 years ago the clock always runs super fast. That's the only issue I have ever had with the unit so it's not a big deal in my opinion, but it would be nice to figure it out.
Nootec, Riocar in a 2001 Honda Civic Coupe
#206957 - 26/02/2004 08:34 Re: My clock runs really Fast [Re: tang_316]
tms13
Loc: Lochcarron and Edinburgh
How fast? Mine gains several seconds a day, but I tolerate it by running ntpdate every time it boots on the network, so it is only noticeably wrong when I have two or three weeks away from the office.
Toby Speight
030103016 (80GB Mk2a, blue)
030102806 (0GB Mk2a, blue)
#206958 - 26/02/2004 11:05 Re: My clock runs really Fast [Re: tang_316]
This is unusual. I've never heard of the clock running fast, I've only heard about it getting reset each time the player is unplugged as described here. Do you think that might be what's happening?
#206959 - 27/02/2004 17:50 Re: My clock runs really Fast [Re: tfabris]
Waterman981
Loc: Salt Lake City, UT
Just to add, mine gains time every day as well, nothing I complain about. In fact the only reason I noticed is Strong Bad tells me every time.
-Michael
#040103696 on a shelf
#206960 - 27/02/2004 17:52 Re: My clock runs really Fast [Re: Waterman981]
Anything more than a few seconds? The original person posting described a large amount but didn't quantify...
#206961 - 27/02/2004 17:54 Re: My clock runs really Fast [Re: tfabris]
Waterman981
Just a few seconds at a time. But over a couple months the clock was 10 minutes fast, so it added up in a hurry.
-Michael
#206962 - 27/02/2004 19:33 Re: My clock runs really Fast [Re: Waterman981]
tang_316
Over the past few days since I have been running the clock, everything seems fine. Not sure what will happen if I remove the player from my car, I will try that tonight. Maybe it was fixed when I upgraded to version 2.00. That might have been the fix, since I have not used the clock function for a year or so.
#206963 - 01/03/2004 11:54 Re: My clock runs really Fast [Re: tang_316]
jbradshw
Loc: Atlanta, GA
Not having this problem, but mine does not keep time no matter what and I have been meaning to post about it. I've had this problem with the player since I bought it 2 years ago. I checked that FAQ entry and none of those apply so I probably do need to contact support... although it's just a clock and not really much to get twisted over.
If I set the time, the next day when I start the car, it will say either Jul-1-2001 or something like Jan-11-2036 (not sure about the Jan 11 part but the year is always 2036).
I was having this trouble with 2.00 final (and betas) and then when I switched to 3.00 a7, the time actually seemed to stay corrected for a couple of days, and then about a week later i looked at it and again it showed the above symptoms. So I don't know what happened there. I'm not using a tuner so RDS is not a factor and I've set the correct time zone and all that.
One of the last MK2's from SonicBlue... Blue/60gig S/N: 030103111
