#208257 - 05/03/2004 00:28 HDD Preparation
crazymelki
Loc: Switzerland
Hello,
Can I prepare a new HDD on my backup device and install it after the preparation in my first device? Are there anything I have to pay attention for this upgrade? Both are MK2 devices.
Thanks for the help in advance.
crazymelki.com
#208258 - 05/03/2004 05:25 Re: HDD Preparation [Re: crazymelki]
As long as they are both Mark2 or 2a model players, you should be able to mix and match however you like. I have done it a few times.
#208259 - 05/03/2004 05:32 Re: HDD Preparation [Re: pgrzelak]
crazymelki
Loc: Switzerland
Thanks..
This means I have to have two devices with the same revision! So I can't mix Mk2 with an MK2a? I understand, that I can't mix an Mk1 with an Mk2 or MK2a.
Thanks Melkon
crazymelki.com
#208260 - 05/03/2004 05:49 Re: HDD Preparation [Re: crazymelki]
No, you should be able to mix and match 2s and 2As. There would be no difference with disk preparation, unless you are building a vary large drive (80GB) on a Mark2 with 12MB of RAM. You *might* run into trouble with that.
#208261 - 05/03/2004 05:55 Re: HDD Preparation [Re: pgrzelak]
crazymelki
Loc: Switzerland
Ok...Thanks a lot for your help
bye
crazymelki.com
