#21164 - 26/10/2000 11:43 Help!!!
craigelliott
Loc: Boothwyn, PA
Running v1.01rc2... was trying to upgrade to v1.01. During the upgrade, it hung halfway through "Programming flash (Kernel)". I had to hit cancel then unplug the empeg. Now when I try to upgrade to v1.01 (or v1.01rc2) it hangs at "Programming flash (Kernel)" and the bar doesn't move across. Using Hyperterminal I get the following results when applying power to the unit:
empeg-car v0.05 19991011 ([email protected])
e000 v1.01
Copying kernel...
Calling linux kernel...
(undefined instruction vector)
Question 1: What do I do? hehehe
Question 2: Did I lose my music?
Question 3: Did I lose my EQ settings?
Thanks for your help in advance... in the meantime, I'm riding in complete silence. :(
Craig Elliott
P.S. also sent a copy to the empeg guys
Craig Elliott
[email protected]
#21165 - 26/10/2000 14:35 Re: Help!!! [Re: craigelliott]
It shouldn't hang during a kernel upgrade no matter what, even if you totally hosed the kernel completely by canceling halfway. Try this:
- Reboot the computer.
- Unplug the power from the Empeg.
- Start a 1.01 kernel upgrade (double check that it's the correct kernel, mark1 or mark2).
- When prompted, apply the power to the Empeg.
See if that fixes it.
#21166 - 26/10/2000 15:10 Re: Help!!! [Re: tfabris]
fvgestel
Loc: Netherlands
Better turn that around:
I've screwed things up once that the empeg would ruin my serial port under win2k when it was connected at boot time
Frank van Gestel
Frank van Gestel
#21167 - 26/10/2000 15:20 RESOLVED! [Re: craigelliott]
craigelliott
Loc: Boothwyn, PA
Well, after Hugo suggested that I use a different computer to apply the upgrade, it finally worked.
I was at work (local college) in the computer lab and all the machines are the same... Gateway 233 MMX. I tried the upgrade on four different computers, and still didn't work. When I finally got home, applied the upgrade with no problem using my home computer.
Craig Elliott
[email protected]
Craig Elliott
[email protected]
#21168 - 27/10/2000 03:51 Re: RESOLVED! [Re: craigelliott]
schofiel
What version of the upgrader were you using?
#21169 - 28/10/2000 19:19 Re: RESOLVED! [Re: schofiel]
craigelliott
Loc: Boothwyn, PA
It didn't matter what version (v1.01 or v1.01-rc2) I tried to flash with from those computers in the lab. Running it on my home computer yielded no problems.
Craig Elliott
[email protected]
Craig Elliott
[email protected]
