#215168 - 03/05/2004 12:04 Is this the dreaded IDE cable problem???
fede
Loc: Texas
Well I do not know what has happened but one of my empegs is going dead each time I boot it up. I get the screen telling me the hijack version and the player version and the last thing I see on the screen is 'starting visuals...'. Then it is completely dead. I have attached the output below. I am no expert on Linux but it looks to me like it can not see the drives. Is this the case or is it something worse?
I am running v3alpha7 and hijack 383 on a MKII. Actually I believe it is one of Mark Lord's cast off machines.
SN#080000316
It has been running beautifully for close to a year since I got it.
Thanks for any advice...
empeg-car bootstrap v1.00 20000601 ([email protected])
On DC power, quick boot
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v383 (root@ibbm) (gcc version 2.95
.3 20010315 (release)) #2 Fri Apr 16 11:15:10 EDT 2004
empeg-car player (hardware revision 7, serial number 80000316)
Command line: mem=12m noinitrd
Memory: 10960k/12M available (980k code, 20k reserved, 324k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 20706d65 'emp '
Tuner: loopback=1, ID=-1
Forced AC/Home mode
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005c00).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DARA-218000, ATA DISK drive
hda: IBM-DARA-218000, 17301MB w/418kB Cache, CHS=35152/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:10:01:3
c
Partition check:
VFS: Mounted root (ext2 filesystem) readonly.
Freeing unused kernel memory: 4k init
Timezone: /usr/share/zoneinfo/Atlantic/South_Georgia
empeg init 0.8
Mounting proc
No secondary hard diskStarting player
/bin/sh: /bin/empegLink: No such file or directory
/bin/sh: exec: /bin/empegLink: cannot exehijack_exec("", "exec /bin/empegLink"),
rc=126 (ERROR)
cute: No such fil[hijack] ERROR: "khttpd_files=0"
e or dire[hijack] ERROR: "khttpd_commands=0"
ctory
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
player.cpp : 564:empeg-car 3.00-alpha7 2004/02/13.
inet_bind(): disabling port 8300/tcp (Emplode)
Prolux 4 empeg car - 2.1490 Feb 13 2004
Vcb: 0x403ee000
'a stock car stereo is a beautiful thing to waste' MKIIa 60gb MKIIa 20gb
#215169 - 03/05/2004 12:33 Re: Is this the dreaded IDE cable problem??? [Re: fede]
It sees a drive:
but not a second one. Are there two?
#215170 - 03/05/2004 12:35 Re: Is this the dreaded IDE cable problem??? [Re: wfaulk]
fede
Loc: Texas
This unit only has one drive. I believe it is a 20GB IIRC.
#215171 - 03/05/2004 12:36 Re: Is this the dreaded IDE cable problem??? [Re: wfaulk]
I am also curious that it cannot find a file as part of an exec statement. If you can get to shell, you might want to verify your config.ini file.
#215172 - 03/05/2004 12:40 Re: Is this the dreaded IDE cable problem??? [Re: pgrzelak]
fede
Loc: Texas
I can't get to shell. It just dies. It is completely non-responsive and the drive seems to spin down. The only way to get it to do anything is to remove power and restart. Of course then it does the same thing all over again. It is a torturous, vicious cycle.
#215173 - 03/05/2004 12:49 Re: Is this the dreaded IDE cable problem??? [Re: fede]
You need to try pressing lots of Q <enter> and ctrl-C commands to be certain that you can't drop to a shell...
#215174 - 03/05/2004 12:49 Re: Is this the dreaded IDE cable problem??? [Re: fede]
How about this?
#215175 - 03/05/2004 13:45 Re: Is this the dreaded IDE cable problem??? [Re: pgrzelak]
fede
Loc: Texas
Thanks for the Control-C tip Tony. I was pressing Q. I did finally get it to a shell prompt. I then tried Paul's suggestion from the FAQ. That is when I got this error in jEmplode...
I have screen shot the dialog and included it as an attachment. The error text is pasted below...
Unable to open connection to device. caused by:
org.jempeg.protocol.ConnectionException: Failed to connect to the specified device. Please verify the device's IP address.
at org.jempeg.protocol.SocketConnection.open(SocketConnection.java:148)
at org.jempeg.empeg.protocol.EmpegProtocolClient.open(EmpegProtocolClient.java:359)
at org.jempeg.empeg.protocol.EmpegProtocolClient.open0(EmpegProtocolClient.java:1068)
at org.jempeg.empeg.protocol.EmpegProtocolClient.readFID(EmpegProtocolClient.java:490)
at org.jempeg.empeg.protocol.EmpegProtocolClient.readFIDToMemory(EmpegProtocolClient.java:421)
at org.jempeg.empeg.protocol.EmpegProtocolClient.getPlayerType(EmpegProtocolClient.java:1082)
at org.jempeg.empeg.protocol.EmpegSynchronizeClient.<init>(EmpegSynchronizeClient.java:41)
at org.jempeg.empeg.manager.dialog.ConnectionSelectionDialog.showConnectionSelectionDialog(ConnectionSelectionDialog.java:157)
at org.jempeg.empeg.manager.Main$1.run(Main.java:88)
at java.lang.Thread.run(Unknown Source)
#215176 - 03/05/2004 16:35 Re: Is this the dreaded IDE cable problem??? [Re: fede]
Greetings!
When you hit control c and ran the player, you need to exit out of the player gracefully and reboot, otherwise the network configuration would not be loaded. That looks like it might have been your problem with jemplode.
#215177 - 04/05/2004 04:38 Re: Is this the dreaded IDE cable problem??? [Re: fede]
tms13
Loc: Lochcarron and Edinburgh
What's in your config.ini?
If you can't get to a shell, you ought to still be able to access the player's files via FTP or HTTP (assuming you haven't disabled those in config.ini!)
Toby Speight
030103016 (80GB Mk2a, blue)
030102806 (0GB Mk2a, blue)
#215178 - 04/05/2004 08:03 Re: Is this the dreaded IDE cable problem??? [Re: pgrzelak]
fede
Loc: Texas
I think that did it. It now starts up and plays fine. The only problem I can think of now is that I do not know what the song was that caused the problem.
When it died, I was in the midst of a higer tier playlist that had a couple of thousand tracks in it.
BTW, I sent you an email. I recieved the tech support sphere yesterday. As the only adult present in the room, all I can say is...
COOL
#215179 - 04/05/2004 08:37 Re: Is this the dreaded IDE cable problem??? [Re: fede]
Cool!
