I still can't see the point of all this; the empeg has temperature sensors on board designed to shut the machine down if it gets too hot or too cold in operation. That is by design. The temperature boundaries for operation are set by the operation ranges of the devices chosen to be in the box, hence if there is a case temperature above or below this threshold, the unit shuts down. This is surely what is happening on your unit. I may be wrong - perhaps there is a problem with the sensor on your unit.
I know you say that you love the empeg, and that you don't want this thread to be negative. I also don't want a firefight here, but all the things you are telling me sound agressive, negative, and are pitched in a manner that get my back up. From my own experience of QA, I would say that you shouldn't be pitching your suggestions this way. It is simply antagonistic and "blame oriented".
What I do see is that you appear to have a problem (which no one else has so far had), you then report it in a strange way on a public BBS and then agressively defend your stance, all without having simply mailed support to ask if this behaviour is normal.
Instead, you have apparently tried using an external fan, to fix a ventilation problem that you have in part caused yourself by obstructing the normal flow of convection air out of the unit, by placing
another powered unit directly above it, with no clearance. You have not said anything about the rest of your install - for example, have you verified the current draw on the remote enable line is below the maximum, since excessive current draw will inevitably cause heating? - so we can only react to what you say here. If it was me dealing with this situation I would have swapped over the unit's positions to see if the situation was improved, and if not, I would be talking to empeg first before kludging in a fix.
There is no doubt you were initially trying to help, and in common with a great deal - in fact, almost the majority - of people on this board, this is only to be applauded. You should not, however, diss suggestions from others who are equally, making a similar attempt to help
you with a problem that you are reporting, directly or indirectly, on this thread. Designs that rely on active forced cooling methods such as a fan are heading for the dumper - the much more elegant passive threshold & convection design of the empeg that doesn't
need a fan at all are to be applauded. Witness the new generation designs from Apple.
I still stand by what I say - you have a problem. You have aggravated it by your installation configuration, which to me seems technically unsound. You have not been conservative in checking that the unit was not at fault with the manufacturer (already well known to be exceedingly concientious about support issues), and fallen back (in my opinion unneccessarily) on a "fix" just to get it working. I know the desperation you can feel to get that empeg in the vehicle and working - I have suffered from it too, you know
- but this is just taking risks, for reasons unknown to me. I wouldn't risk my 800 pound stereo like this, for the same reasons you state!
This to me is an extremely strange way to proceed with issues relating to a high-value electronic device, and coming from one who professes to have training in electronics and works in QA, I am left puzzled and, to be honest, upset by your attitude. I would not like to have you feel that I am sounding "hostile", and I suspect you will - but I am still left with the feeling that I am fending off a knife attack out of the blue.
One of the few remaining Mk1 owners...
#00015
