#215309 - 05/05/2004 09:02 OK... now what?
jem7784
I removed my second hard drive because of problems with it. The primary was working but database was messed up so wanted to clear it out. Used the disk builder to format and then installed the 2.0 final software. All was fine and I tried to sync overnight with Jemplode and install stuff. I woke up and Jemplode exited with no errors, but nothing was installed. Then tried to sync again and it said database errors. Well, I cannot get into anything. I tried reformatting and it will not do it. It locks. So I tried several things and it will not boot at all. I get the following on hyperterminal
player(25): memory violation at pc=0xe15001a0, lr=0x020dc9c8 (bad address=0xe150
01a0, code 2)
pc : [<e15001a0>] lr : [<020dc9c8>]
sp : bffffe60 ip : bffffe7c fp : bffffe78
r10: 02031730 r9 : 00000000 r8 : 00000001
r7 : bfffff64 r6 : 0212a47c r5 : 02126484 r4 : 0214ee30
r3 : e15001a1 r2 : 0214ee30 r1 : 020f29c4 r0 : 00000008
Flags: NzCv IRQs on FIQs on Mode USER_32 Segment user
Control: C0F7517D Table: C0F7517D DAC: 00000015
Function entered at [<020dc9a0>] from [<020f29c4>]
r6 = 0212A47C r5 = 02126484 r4 = 0214EE30
Function entered at [<020f29ac>] from [<021093a4>]
r4 = 0214F888
Function entered at [<02109374>] from [<020f2924>]
r10 = 02031730 r9 = 00000000 r8 = 00000001 r7 = BFFFFF64
r6 = 0212A47C r5 = 02126484 r4 = 0214F888
Function entered at [<020f28d4>] from [<020f2cb8>]
r5 = BFFFFF6C r4 = 0212A478
Function entered at [<020f2c78>] from [<020f2c30>]
r8 = 02112060 r7 = 00000000 r6 = BFFFFF64 r5 = 00000001
r4 = BFFFFF6C
Function entered at [<020f2bcc>] from [<020f2c60>]
r6 = 020000C0 r5 = BFFFFF64 r4 = 00000001
Function entered at [<020f2c50>] from [<020c8e6c>]
Function entered at [<020c8dc8>] from [<02000104>]
r10 = 00000000 r8 = 00000000 r7 = 00000000 r6 = 00000000
r5 = 00000000 r4 = 00000000
Restored terminal settings
No secondary hard disk
Abnormal player termination
Player received signal 11
Starting playTimezone: /usr/share/zoneinfo/Atlantic/South_Georgia
er
player(26): memory violation at pc=0xe15001a0, lr=0x020dc9c8 (bad address=0xe150
01a0, code 2)
r4 = 0214F888
r4 = BFFFFF6C
er
player(27): memory violation at pc=0xe15001a0, lr=0x020dc9c8 (bad address=0xe150
01a0, code 2)
r4 = 0214F888
r4 = BFFFFF6C
On and on.. It will do nothing at all... Anyone with any ideas?
Jemmi
#215310 - 05/05/2004 09:17 Re: OK... now what? [Re: jem7784]
That looks bad. Like memory errors bad. Try running the memory diagnostics: Ctrl-T as soon as the player powers on.
#215311 - 05/05/2004 10:12 Re: OK... now what? [Re: wfaulk]
Also, because you ran disk builder, I would look for a builder bug. You may need to rebuild the disk.
#215312 - 05/05/2004 10:37 Re: OK... now what? [Re: pgrzelak]
jem7784
I ran disk builder about 6 times... and reinstalled the software about the same number of times. I just took it apart and got it to boot and all... I have no idea if I've fixed the problem at all as the upload issue is what started all of this...
