#215685 - 07/05/2004 18:33 Need referral, south San Francisco Bay
DrGuz
Anybody willing to refer me to a pro installer in the south San Francisco Bay area? The closer to Sunnyvale, the better. Many months ago there was some buzz about local shops specializing in empeg / RioCar, but I can't seem to turn any of that up on the forum searches now.
Got a RioCar that doesn't want to power up in an existing MkII sled, though it works fine off wall power. And I have zero skills to bear toward fixing it myself.
Thanks!
#215686 - 08/05/2004 00:40 Re: Need referral, south San Francisco Bay [Re: DrGuz]
mtempsch
If you've got a MkIIa unit and a MkII sled and it won't power up, the problem most likely lies in the constant +12V wire/connections.
A MkII can be completely powered from the switched +12V line alone, but the MKIIa uses the switched +12V ONLY for telling it to turn on/off while drawing all power from the constant +12V line. See this FA Question
Even if you can't fix it yourself, this might help speed up troubleshooting for whoever that will do it...
#215687 - 08/05/2004 18:45 Re: Need referral, south San Francisco Bay [Re: DrGuz]
Also check for this problem which I'll see if I can sub-link from the FAQ you just got FAQed on.
#215688 - 10/05/2004 13:12 Re: Need referral, south San Francisco Bay [Re: tfabris]
Also, check all the applicable fuses (sled, line from battery, etc.)
