#216394 - 17/05/2004 10:27 empeg without display or discs
skibum
Loc: Swindon, UK
I've received the memory from Paul to upgrade my 2a to 32mb. A friend of a friend is hopefully going to be doing it at work as they have all the right stuff. However, she's not empeg aware.
So I was wondering if I can just send her the system board, psu and a serial cable, and if she'll then be able to test the empeg enough to know if the memory upgrade worked?
#216395 - 17/05/2004 10:56 Re: empeg without display or discs [Re: skibum]
Yes. You should be able to hook up the serial port, flash the latest hijack on there and watch the boot cycle. You should be able to execute a memory test, along with the self test, and get boot logs of each.
#216396 - 17/05/2004 11:05 Re: empeg without display or discs [Re: pgrzelak]
Tasks which would probably be a bit tricky for someone who's not "empeg-aware"... They would need coaching on all of those steps.
#216397 - 17/05/2004 11:11 Re: empeg without display or discs [Re: tfabris]
Agreed. Perhaps pre-flashing the unit with the most recent hijack would be in order. As for the boot logs, that is pretty much covered in the FAQ, so generating instructions should be mostly harmless.
#216398 - 17/05/2004 11:47 Re: empeg without display or discs [Re: pgrzelak]
skibum
Loc: Swindon, UK
Thanks guys. Just checking it would still do something :-)
Got hijack v390 with ext3 already loaded. But as Tony said will require some coaching. Still trying to find out if she'll even have access to a PC while doing it. Of course she could be the best solderer in the world for all I know :-)
#216399 - 18/05/2004 02:40 Re: empeg without display or discs [Re: skibum]
Sure the empeg will still work with no display board at all? I understand a dud VFD and it will still work but no board at all?
It might expect to be able to talk to the PIC that controls the buttons etc.
#216400 - 18/05/2004 05:05 Re: empeg without display or discs [Re: Shonky]
I was able to use mine, in a somewhat limited way, without the VFD. Granted, you couldn't see or control much without display module, but with alternate input (ethernet or serial) you can still control it.
#216401 - 18/05/2004 05:10 Re: empeg without display or discs [Re: pgrzelak]
OK. Cool. As long as it has been tried before. Wouldn't want to send only part of it away for it to not work.
