#217941 - 09/06/2004 11:00
Re: Several problems all at once :-(
[Re: sundayjumper]
Yep.
#217942 - 09/06/2004 11:30
[Re: pgrzelak]
Loc: West Berkshire
Oh.....
empeg:/empeg/bin# ro
mount: /drive0 not mounted already, or bad option
empeg:/empeg/bin# umount /dev/hda4
umount: /dev/hda4: not found
empeg:/empeg/bin# swapon /swapfile
Adding Swap: 16028k swap-space (priority -1)
empeg:/empeg/bin# fsck -fay /
Parallelizing fsck version 1.19 (13-Jul-2000)
e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
hda5 is mounted.
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
/dev/hda5: 1514/4096 files (0.5% non-contiguous), 9457/16384 blocks
empeg:/empeg/bin# fsck -b 32768 -fay /dev/hda4
hda4 is mounted.
fsck.ext2: Bad magic number in super-block while trying to open /dev/hda4
The superblock could not be read or does not describe a correct ext2
filesystem. If the device is valid and it really contains an ext2
filesystem (and not swap or ufs or something else), then the superblock
is corrupt, and you might try running e2fsck with an alternate superblock:
e2fsck -b 8193 <device>
No good ?
Steve.
Mk2a 10+40Gb Darkstorm Neon Red
Nakamichi CD45z, Genesis Five Channel, Genesis A16s, JL 8W6 x3
#217943 - 09/06/2004 12:04
[Re: sundayjumper]
No good ?
No, not good. Try each of these alternate numbers:
32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208
These are from the new recommended format scheme, though; the scheme used by the builder might not have put the superblocks in the same place.
#217944 - 09/06/2004 12:25
[Re: Roger]
Loc: West Berkshire
Still no good. Every time, I get:
hda4 is mounted.
Steve.
#217945 - 09/06/2004 12:30
[Re: sundayjumper]
Doubleplusungood.
I think it's time for mke2fs with the -S flag as a last ditch effort. Roger, will mke2fs -S /dev/hda4 do it or does he need other flags?
#217946 - 09/06/2004 12:33
[Re: genixia]
Before the -S, it might be worth it to try the dry run -n. It might be that the superblocks from the default builder are in different locations.
#217947 - 09/06/2004 13:14
[Re: pgrzelak]
Loc: West Berkshire
So a "mke2fs -n -m 0 -b 1024 -i 131072" ?
FWIW I'm now not too worried about losing the stuff on there, a lot of it was badly ripped anyway !
Steve.
#217948 - 09/06/2004 13:17
[Re: sundayjumper]
Yes. You might want to capture this to a log file and post the results here.
#217949 - 09/06/2004 13:28
[Re: pgrzelak]
Loc: West Berkshire
Looks like it doesn't recognise the -n flag:
empeg:/empeg/bin# mke2fs -n -m 0 -b 1024 -i 131072
mke2fs 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
Usage: mke2fs [-c|-t|-l filename] [-b block-size] [-f fragment-size]
[-i bytes-per-inode] [-N number-of-inodes]
[-m reserved-blocks-percentage] [-o creator-os] [-g blocks-per-group]
[-L volume-label] [-M last-mounted-directory] [-O feature[,...]]
[-r fs-revision] [-R raid_opts] [-s sparse-super-flag]
[-qvSV] device [blocks-count]
Steve.
#217950 - 09/06/2004 13:33
[Re: sundayjumper]
Worth a shot. Given that there does not appear to be a non-destructive way to find superblock locations, I do not know what else to tell you. It might be time for that -S switch.
Does anyone else have any ideas???
#217951 - 09/06/2004 14:08
[Re: pgrzelak]
Loc: San Carlos, CA
Might be worth trying a newer version of fsck. There is a more recent version on my ext3 page.
Just grab the e2fsck binary and ftp it to your player and then follow step 1 (and only step 1) on that page. Then try the fsck again.
-Mike
#217952 - 10/06/2004 08:29
[Re: mcomb]
Loc: West Berkshire
OK, I tried doing mcomb's suggestion, but I'm not quite sure what happened. I then did the -s whatsit and got this:
empeg:/empeg/bin# mke2fs -S /dev/hda4
hda4 is mounted.
Filesystem label=
OS type: Linux
Block size=4096 (log=2)
Fragment size=4096 (log=2)
4872896 inodes, 9741414 blocks
487070 blocks (5.00%) reserved for the super user
First data block=0
298 block groups
32768 blocks per group, 32768 fragments per group
16352 inodes per group
Superblock backups stored on blocks:
32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208,
4096000, 7962624
Those last two numbers are new, so I tried the fsck command again with the first of the new numbers but get fsck: fsck.ext2: not found I think I've screwed something up.
Steve.
#217953 - 10/06/2004 09:11
[Re: sundayjumper]
No, I think that error is because you copied the new fsck across.
Can you do ls -l /sbin/e2* and ls -l /sbin/fsck*
#217954 - 10/06/2004 09:59
[Re: genixia]
Loc: West Berkshire
empeg:/empeg/bin# ls -l /sbin/e2* and ls -l /sbin/fsck*
ls: and: No such file or directory
ls: ls: No such file or directory
lrwxrwxrwx 1 0 0 11 Jun 10 17:24 /sbin/e2fsck -> /bin/e2f
sck
lrwxrwxrwx 1 0 0 16 Jun 10 17:25 /sbin/e2fsck.ext2 -> /bi
n/e2fsck.ext2
-rwxr-xr-x 1 0 0 66301 Apr 1 2003 /sbin/fsck
lrwxrwxrwx 1 0 0 11 Jun 10 16:40 /sbin/fsck.ext2 -> /bin/
e2fsck
So what's that doing ?
Steve.
#217955 - 10/06/2004 10:05
[Re: sundayjumper]
Checking what is where...
ls -l /bin/e2*
ls -l /bin/fsck*
Note the path change, bin not sbin this time.
#217956 - 10/06/2004 10:15
[Re: genixia]
Loc: West Berkshire
empeg:/empeg/bin# ls -l /bin/e2*
lrwxrwxrwx 1 0 0 11 Jun 10 17:24 /bin/e2fsck -> /bin/e2fsck
lrwxrwxrwx 1 0 0 16 Jun 10 17:25 /bin/e2fsck.ext2 -> /bin/e2fsck.ext2
empeg:/empeg/bin# ls -l /bin/fsck*
-rwxr-xr-x 1 0 0 66301 Apr 1 2003 /bin/fsck
lrwxrwxrwx 1 0 0 11 Jun 10 16:40 /bin/fsck.ext2 -> /bin/e2fsck
#217957 - 10/06/2004 10:29
[Re: sundayjumper]
There's your problem. Somehow in putting the newer e2fsck tools on the player something got screwed up.
fsck is trying to call fsck.ext2 which symlinks to /bin/e2fsck which in turn symlinks to ... itself. You're missing the e2fsck binary.
#217958 - 11/06/2004 02:33
[Re: genixia]
Loc: West Berkshire
Erk. I knew I shouldn't have got up this week. I'm in way over my head now so I think I'll cut my losses and rebuild the drive.
Many thanks to everyone for the help :-)
Steve.
