I have been trying to get trio to work, but it just wont. Here is what I did so far
I downloaded versions 1.4alpha5 of both trio and riot
extracted the arm to the audio reciver directory (replacing the original - I backed it up) then I extracted trio to d:\program files\trio
Next I edited the trio.xml file - followed the directions to a tee and re-checked it 4 times
next edited the batch file in the bin dir
started audioreciever - imported music, turned on the rio - got the trio spalsh screen, started trio.bat - rio now says connecting to server and thats where it all ends. I have included the etext from the dos screen thats running trio below.
PS - also tried to get it working with jreciever and no luck
(i am running pcanywhere on the same server if that makes a difference)
D:\Program Files\trio\trio-0.1.4.alpha5\bin>set TRIO_HOME=D:\Program Files\trio\
trio-0.1.4.alpha5
D:\Program Files\trio\trio-0.1.4.alpha5\bin>rem set JAVA_HOME=c:\Program Files\j
2re1.4.2
D:\Program Files\trio\trio-0.1.4.alpha5\bin>cd D:\Program Files\trio\trio-0.1.4.
alpha5
D:\Program Files\trio\trio-0.1.4.alpha5>java -X"bootclasspath:D:\Program Files\t
rio\trio-0.1.4.alpha5\lib\pja-mod.jar;C:\Program Files\Java\j2re1.4.2_02\lib\rt.
jar" -Dawt.toolkit=com.eteks.awt.PJAToolkit -Djava.class.path="C:\Program Files
\Java\j2re1.4.2_02\bin\lib\tools.jar;C:\Program Files\Java\j2re1.4.2_02\bin\lib\
jsse.jar;D:\Program Files\trio\trio-0.1.4.alpha5\lib\trio-0.1.4.jar;D:\Program F
iles\trio\trio-0.1.4.alpha5\lib\commons-logging.jar;D:\Program Files\trio\trio-0
.1.4.alpha5\lib\commons-beanutils.jar;D:\Program Files\trio\trio-0.1.4.alpha5\li
b\commons-collections.jar;D:\Program Files\trio\trio-0.1.4.alpha5\lib\commons-di
gester.jar;D:\Program Files\trio\trio-0.1.4.alpha5\lib\commons-lang.jar;D:\Progr
am Files\trio\trio-0.1.4.alpha5\lib\jrcommon.jar;D:\Program Files\trio\trio-0.1.
4.alpha5\lib\jrutil.jar;D:\Program Files\trio\trio-0.1.4.alpha5\lib\jrclient.jar
;D:\Program Files\trio\trio-0.1.4.alpha5\lib\xmlrpc.jar" trio.TRioServer "-cD:\P
rogram Files\trio\trio-0.1.4.alpha5\trio.xml"
Start of TRioServer. Version 0.1.4.alpha5
Defaulted http document root to: D:\Program Files\trio\trio-0.1.4.alpha5
Loading TRioPlayerLayout: universal
Loading TRioPlayerLayout: windows
ImageTranslation: byte-binary
RMI Registry created sucessfully on port 1099
binding rmi: rmi://192.168.0.189:1099/TRioServerRemote
binding rmi: rmi://win2ksvr:1099/TRioServerRemote
Creating sockets
creating udp socket. local port: 19680, timeout: 15000
Http server opening port 8090
Http server listening on port 8090
Got connect from /192.168.0.160
TRioUnitControlThread (/192.168.0.160): Starting
TRioUnitControlThread (/192.168.0.160): Waiting for Rio to accept connection. i
p: /192.168.0.160, port: 19682
TRioUnitControlThread (/192.168.0.160): Rio has accepted connection. Interface:
/192.168.0.189
Thats it goes no further and rio is locked up
