#227249 - 15/07/2004 15:34 Syncing problems in v3
I've been using v3 for a bit now most recently alpha7. Anyways, when I try to sync new music in emplode it's usually 50/50 as to wether it works, this is apparent in alpha8 too. What usually happens is it gets as far as mounting R/W, deleting the databases and then stalls at the first playlist to add. I've left it for up to an hour with no avail. Other times it just zips through and works. Anyone else have this?
#227250 - 15/07/2004 15:41 Re: Syncing problems in v3 [Re: andym]
Waterman981
Loc: Salt Lake City, UT
I do as well. I have tried over ethernet, and USB with multiple cables... Haven't tried over serial. (3.0a7 only)
-Michael
#040103696 on a shelf
#227251 - 15/07/2004 16:21 Re: Syncing problems in v3 [Re: andym]
Time to do the obvious next step.. hook up the serial port and watch for error messages during the USB/ethernet sync operation. Post them once collected.
#227252 - 15/07/2004 17:53 Re: Syncing problems in v3 [Re: mlord]
I'm not 100% sure but I think I've looked on the serial port and not seen anything, I'll give it another go later.
#227253 - 16/07/2004 10:54 Re: Syncing problems in v3 [Re: andym]
jem7784
Same thing happens to me.. serial port doesn't show any problems... I have asked repeatedly before and I thought it was just me until the last week or so when I've seen 2 other posts abotu this..
Jemmi
#227254 - 19/07/2004 16:27 Re: Syncing problems in v3 [Re: andym]
shapeless
Loc: Italy
got the same problem and downgraded to v2
look here:
http://empegbbs.com/ubbthreads/showflat....true#Post225425
shapeless
MK2a | #010101588 | 2x 120GB SSD  | Hijack v526 | v3.0a11 | > melpomene <
MK2   | #090000581 | 60 & 100GB HD | v2final.mk2 | v2.01 | > backup <
radio | all colors lens | greenlights LBSSK buttons | KCA-R6A + ERC-1A remotes | carry cases | empeg sticker!
#227255 - 21/07/2004 20:17 Re: Syncing problems in v3 [Re: andym]
Defiler
I occasionally get stuff like this (just recorded this log):
Adding Swap: 16028k swap-space (priority -1)
e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
ext2fs_check_if_mount: No such file or directory while determining whether /dev/hda4 is mounted.
ext2fs_check_if_mount: No such file or directory while determining whether /dev/hdc4 is mounted.
server_protocol_handler.cpp:1389:Timeout during synchronise, restarting player
Timezone: /usr/share/zoneinfo/Atlantic/South_Georgia
player.cpp : 564:empeg-car 3.00-alpha7 2004/02/13.
! tags.cpp : 61:Failed to open tags (0xc0041002).
Prolux 4 empeg car - 2.1490 Feb 13 2004
Vcb: 0x4070e000
I get various other syncing errors as well. I'll post log entries as they occur.
#227256 - 21/07/2004 20:33 Re: Syncing problems in v3 [Re: Defiler]
They're all normal apart from these two:
It looks like it lost the connection to the PC running Emplode, jEmplode and therefore the sync wasn't completed properly.
