#233479 - 14/09/2004 18:07 Music missing, Emplode crashes
Joe Gorman
Loc: Oak Hill, WV, USA
When I plug in my MK2 30 gig, (running 2.0), it takes much longer to boot (while displaying AC Power image (Home) on the display (currently have no car to test this in) ...the hard drive's making funny noises on me, "whrrr, click-click, whrrr, click-click," etc. Once it's done, it displays "End of playlist" and shows -None- when I go to the dropdown menu for playlists. When I try to synchronize while loading Emplode, it gets to "Checking media...Checking disc integrity" and briefly displays "Waiting..." then the program suddenly closes. The player has close to 30 gigs on it. What other information do you guys need to help me out?
Edited by MadPJ7 (14/09/2004 18:09)
#233480 - 14/09/2004 19:02 Re: Music missing, Emplode crashes [Re: Joe Gorman]
You gave all the information we needed right here:
So... Please click here and go through that list, one item at a time, checking every one of the possible causes for hard disk trouble listed there.
#233481 - 14/09/2004 19:06 Re: Music missing, Emplode crashes [Re: tfabris]
Joe Gorman
In other words, it can do everything up to the point of finding the music without the use of the hard drive?
#233482 - 14/09/2004 19:10 Re: Music missing, Emplode crashes [Re: Joe Gorman]
Hard disk trouble can be "partial". Clearly some of the hard disk is working because it can load the player software. But it's clearly not working properly because of the noise it's making.
#233483 - 15/09/2004 04:32 Re: Music missing, Emplode crashes [Re: tfabris]
Joe Gorman
I took it apart, and it appears to be none of the above. At first it looked like it could be the crimping on the IDE cable, but no luck. The unit sat for a few months while I had my stuff in storage between spring and fall semester, but the box was clearly not dropped or mishandled (it worked last time it was plugged in). If the hard drive is, in fact, damaged, any chance that my music may be salvageable?
#233484 - 15/09/2004 09:01 Re: Music missing, Emplode crashes [Re: Joe Gorman]
Can you post a boot log (to see if you are having disk trouble at boot) and how comfortable at troubleshooting on the command line?
#233485 - 15/09/2004 15:42 Re: Music missing, Emplode crashes [Re: Joe Gorman]
Is it possible that the unit was exposed to extreme temperatures while in storage?
Sure, after you replace the empeg's hard disk, just upload your tunes again from your PC. You did keep a backup of the files on your PC, right? If not, then just re-rip from the original CDs (the ultimate backup).
#233486 - 15/09/2004 20:51 Re: Music missing, Emplode crashes [Re: pgrzelak]
Joe Gorman
I'll post a boot log as soon as I can find a serial cable that works, I used the FAQ and searching these forums to find instructions. I'm code-illiterate, though, so someone here'll have to help me source the problem from that point.
#233487 - 15/09/2004 20:55 Re: Music missing, Emplode crashes [Re: tfabris]
Joe Gorman
Temperatures were mild this summer and couldn't have been much above 80 degrees on any occasion. As for the music, most of it is directly off of friends' computers, in true p2p fashion. It would be a serious headache to upload the music again, as this summer was the year that most of my friends packed up their computers and left for college.
#233488 - 16/09/2004 01:46 Re: Music missing, Emplode crashes [Re: pgrzelak]
Joe Gorman
In the boot log, it pauses at "Freeing unused kernel memory: 4k init"
Here is the boot log, in its entirety:
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg52 (rob@aphex) (gcc version 2.95.3 20010315
(release)) #12 Tue Apr 1 18:51:41 BST 2003
empeg-car player (hardware revision 9, serial number 30102965)
Command line: mem=16m
Linux NET4.0 for Linux 2.2
Based upon Swansea Universit
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 636f6972 'rioc'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005400).
empeg RDS driver initialised
RAM disk driver initialized: 16 RAM
empeg single channel IDE
Probing primary interface...
hda: FUJITSU MHL2300AT, ATA DISK drive
hda: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0b:9
5
Partition check:
empeg-pump v0.03 (19980601)
Freeing unused kernel memory: 4k inithda: irq timeout: status=0xd0 { Busy }
ide0: reset: success
end_request: I/O error, dev 03:04 (hda), sector 4
EXT2-fs: Couldn't read superblock on 2nd try.
hda: status timeout: status=0xd0Busy hda: drive not ready for command
! tags.cpp : 61:Failed to open tags (0xc0041002).
Vcb: 0x4086d000
Thank you guys for the help, this is the most helpful forum I have ever been a member of.
Many thanks
-Joe
#233489 - 16/09/2004 01:54 Re: Music missing, Emplode crashes [Re: Joe Gorman]
Um.....
#233490 - 16/09/2004 02:15 Re: Music missing, Emplode crashes [Re: tfabris]
Joe Gorman
What does it mean? Call me a pessimist, but it sounds like you have bad news for me about my hard drive?
#233491 - 16/09/2004 02:38 Re: Music missing, Emplode crashes [Re: tfabris]
genixia
Hmm, isn't the player software on the root partition, ie in flash?
My money is on the IDE header.
#233492 - 16/09/2004 03:59 Re: Music missing, Emplode crashes [Re: genixia]
There is something wrong with either specific sectors on the hard disk, or there is something wrong with the connection to the hard disk, such as the IDE header problem Genixia mentioned. Was that one of the things you checked carefully for?
To my knowledge, only the kernel is in flash, and the player software is on the hard disk. His empeg is getting far enough to load at least some of the player software, then it gives some hard disk errors. I don't know enough about what the errors mean to know what the issue is with the hard disk.
#233493 - 16/09/2004 05:18 Re: Music missing, Emplode crashes [Re: tfabris]
Joe Gorman
...or there is something wrong with the connection to the hard disk, such as the IDE header problem Genixia mentioned. Was that one of the things you checked carefully for?
It was the thing I most carefully checked. I made the crimps a little tighter, though they weren't bad to start with...no difference in the player. I never say I'm 100% sure about these things, and I'd love someone to show up with a perfect cable and prove me wrong, but it doesn't look like an IDE cable problem from here.
Assuming the problem isn't so simple, what's my next step?
#233494 - 16/09/2004 08:12 Re: Music missing, Emplode crashes [Re: Joe Gorman]
Take a very close look at the IDE connector on the main board itself. You might see pins of the header pulled away. Although you may need a zoom camera or magnifier to see it, those dry solder joints are very common and would need a bit of soldering to touch them up.
#233495 - 16/09/2004 12:24 Re: Music missing, Emplode crashes [Re: pgrzelak]
They're referring to this problem:
Make sure you carefully check all the contacts, and not just the pictured ones.
#233496 - 17/09/2004 01:50 Re: Music missing, Emplode crashes [Re: JBjorgen]
Joe Gorman
I found a magnifying glass today and checked these connections more closely (9x more closely, to be specific). Could not see any broken connections at the base, even while gently "wiggling" the connector. The solder joints actually look very good in my Riocar.
#233497 - 23/09/2004 02:02 Re: Music missing, Emplode crashes [Re: JBjorgen]
Joe Gorman
I found similar hard drive error messages here , here , and here. I'll try doing a RAM test, and hopefully Sunday someone will be touching up the solders and professionally re-crimping the cables for me or possibly even making new ones (I spent most of this week making friends with the local computer tech geniuses). Is anyone local to the DC area and willing to lend me an IDE cable that they know is in working order? Or possibly an Empeg to test out my drive in?
#233498 - 15/11/2004 19:52 Re: Music missing, Emplode crashes [Re: Joe Gorman]
Joe Gorman
Well it turned out to be the hard drive after all. I have a 2gb unit on loan to me while I anxiously await my birthday party (there's a rumor that someone bought me an 80gb unit a few months back, I still haven't had a party yet).
Hoping it's just one sector with damage that stopped the music from loading, a geek friend is setting up a Linux box in an attempt to salvage 30gb of my old music.
Thank you all for your help! It's apparent the hard drive has been replaced at least once before, so I'm investigating anything that could cause repeated hard drive failure.
#359783 - 20/09/2013 01:23 Re: Music missing, Emplode crashes [Re: Joe Gorman]
Joe Gorman
Well, left the player sitting for a while (since moving last April) and when I started it up, makes whooshy crashy noises and "No hard disk found."
I don't have a serial port on my computer, but I'll see if tomorrow I can take it to someone who does so I can post a bootlog.
This will have been the player's third hard drive...are there any known issues that cause repeat hard drive failure?
#359793 - 20/09/2013 10:42 Re: Music missing, Emplode crashes [Re: Joe Gorman]
Heat.
#359794 - 20/09/2013 11:26 Re: Music missing, Emplode crashes [Re: mlord]
Heat.
That's the trouble with you, Mark. You go into these long, wordy, elaborate discourses that are so full of technicalitites and polysyllabifications that you have to be an engineer* to understand them.
*Two MIT engineering students meet on the quad, and one of them has a shiny new bicycle. "Hey, where'd you get the bike?" the second one asks. "You'd never believe it", the first one says, "But the other day this beautiful woman came riding up to me, threw the bike down, tore off all her clothes, and said to me, 'Take anything you want!'" The second student says, "Good choice. Her clothes never would have fit you."
