Page 2 of 2 < 1 2
#233922 - 19/09/2004 23:23 Re: jEmplode 63 [Re: tfabris]
mschrag
Loc: Richmond, VA
64's not quite ready yet, but here's what will be in it:
Tentative 64 CHANGES:
Option to disable removing articles for comparisons (look in Options menu). You will need to drop and readd your soups for this to function properly in your soups (it won't retroactively update)
Regex search (title regex "^[a-z]")
Track numbers are sorted numerically (actually, the same comparison is used in soups as in table column sorting, so dates are sorted properly as well)
Empty fields are left empty rather than setting to "(none)" .. a bunch of (none)'s just looks busy
Option to enable Tony Selections
Rebuild-on-PC is back (check Options panel, off by default)
Fast rebuild from memory is back (check Options panel, off by default)
Reordering of soup playlists when aggregate tags change
#233923 - 19/09/2004 23:25 Re: jEmplode 63 [Re: mschrag]
cushman
Loc: Erie, CO
We should call this version "Ultimate jEmplode". Thanks for all your work, I know we all appreciate it!
Mark Cushman
#233924 - 19/09/2004 23:35 Re: jEmplode 63 [Re: mschrag]
Daria
Woot, finally I can upgrade!
So I can de-select Fabris and select Cebzanov? I'm not sure what I'd do with it, but I suppose a use might crop up.
#233925 - 19/09/2004 23:51 Re: jEmplode 63 [Re: mschrag]
Mike, you are The Man.
And Derrick, I don't think it's hugely important which Tony you select. We're all the same, you know.
#233926 - 20/09/2004 00:51 Re: jEmplode 63 [Re: tfabris]
Daria
Nah. The other one's not scared of Unix
#233927 - 20/09/2004 03:10 Re: jEmplode 63 [Re: Daria]
Hey, that's NOT TRUE. I just don't use it daily. Day job: Windows. Evening: Gaming. I'm not scared of it, I just have other stuff in my life at the moment.
#233928 - 20/09/2004 03:32 Re: jEmplode 63 [Re: tfabris]
Daria
So you say, but is there any evidence to the contrary? I think you're just trying to hoodwink me.
#233929 - 20/09/2004 09:19 Re: jEmplode 63 [Re: mschrag]
Happy Birthday SonicSnoop
Loc: Triangle, VA
Am I the only one that the check boxes for ignore child, randomize, etc dont work under the properties of a playlist? I mentioned it before but dont recall if anyone ever said they had it happen as welll
#233930 - 20/09/2004 11:03 Re: jEmplode 63 [Re: SonicSnoop]
mschrag
Loc: Richmond, VA
They didn't ... and they will. I thought it was actually a really nasty problem for a long time so I didn't even look at it. Turns out I'm just a retard and the checkboxes weren't hooked up to do anything.
#233931 - 20/09/2004 13:42 Re: jEmplode 63 [Re: mschrag]
Loc: Triangle, VA
ok Thanks!
Page 2 of 2 < 1 2
