#239059 - 26/10/2004 21:03 Player not booting
cob666
Hi....
My MK2a isn't booting. I connected to terminal server and the machine kept cycling through the prompt to upgrade the flash. I ran logo editor and installed the Hijack kernel. After applying the patch and then connecting to terminal server I get the 'Let the Penguins Fly' message but then it hangs at
(data abort vector)
any suggestions?
-Chris
MKII 24G SN# 8000333 MKIIa 30G
#239060 - 26/10/2004 21:20 Re: Player not booting [Re: cob666]
did you get the happy face at the end of the logoedt kernel installation?
Are you ***** S U R E ***** the kernel .zimage file was correct and was not corrupted? What did you use to download that kernel file?
Also do a RAM test, described in the FAQ about using hyperterminal.
#239061 - 26/10/2004 22:30 Re: Player not booting [Re: tfabris]
cob666
Hi Tony...
I actually did get the smiley face after the kernal upload. I was quite pleased (if only for a VERY short period of time) with myself.
I just used firefox to download the file and have not yet encountered a bad download. I would have performed a CRC check but didn't have any information about the correct checksum. I also did perform the RAM test by pressing CTRL-T during power-up and didn't get any errors during the check.
This happened quite suddenly. The player worked in my car this morning, I brought it in the house to upload some additional songs and the empeg wouldn't boot up when I plugged in the adapter. I didn't drop it.
I also couldn't find any information about the (data abort vector) message instead of telling me that the kernel was loading into memory.
Is there something in particular I could check or is there a way to force the bootup into a more extreme diagnostic mode?
Thanks again!
#239062 - 27/10/2004 00:22 Re: Player not booting [Re: cob666]
cycle power, and see if it boots from power-on.
#239063 - 27/10/2004 02:20 Re: Player not booting [Re: cob666]
Just for the heck of it, try downloading the zimage file with IE instead of Firefox.
Also, make sure that it's the correct zimage file for your player, in other words, if you have a Mk2, then make sure the get the Mk2 version of the zimage file. Then try applying agin.
#239064 - 27/10/2004 02:21 Re: Player not booting [Re: tfabris]
Oh. And try flashing and then booting the player with the hard disks completely removed. See if it boots the kernel then.
#239065 - 27/10/2004 04:32 Re: Player not booting [Re: cob666]
I'm guessing it no longer boots up in the car as well?
#239066 - 27/10/2004 05:23 Re: Player not booting [Re: tanstaafl.]
Oh yeah, doug's got a point!!! Could just be a bad AC adapter that doesn't have enough power to spin up the disk drives. As the drives spin up, voltage goes down and bam.
#239067 - 27/10/2004 10:34 Re: Player not booting [Re: tfabris]
cob666
I initially did the power off and boot up with no HD attached and got the Abort Vector message. Also, the player doesn't boot up the car either. When I run the self-test (CTRL-T) the drive spins up and everything sounds OK but during a normal boot I hear no drive activity on boot and it looks like the kernel isn't even loading.
I will try to re-download the kernel and re-apply and see what happens there.
Any chance that one of the developers can tell me what that message actually means and/or what the player is trying to do? That might help me narrow down the problem or let me know that I need to send the unit in for repair.
-Thanks
#239068 - 27/10/2004 13:18 Re: Player not booting [Re: cob666]
The message means "reflash the kernel".
#239069 - 27/10/2004 13:21 Re: Player not booting [Re: mlord]
cob666
Excellent.
I will re-download the hijack kernel and try again. Unless there is a different player image I should be using to flash some life back into my player!
-Chris
#239070 - 27/10/2004 15:27 Re: Player not booting [Re: cob666]
RobotCaleb
reflash with the developer image first, then apply the hijack again.
#239071 - 27/10/2004 16:23 Re: Player not booting [Re: cob666]
Just use the download program, or Tony's Logo Editor, to reflash only the Hijack kernel. No need to do a full reinstallation yet.
#239072 - 27/10/2004 16:25 Re: Player not booting [Re: mlord]
Yeah, we want to see if the kernel and flash are working at all before trying to go to the trouble of installing an entire hard disk partition.
Definitely try the kernel flash with no disks installed to see if the flash takes and if the kernel can boot without the disks.
#239073 - 27/10/2004 21:09 Re: Player not booting [Re: tfabris]
cob666
I re-downloaded (several times) this kernel:
v413.hijack.mk2.zImage
and applied it also several times and keep getting the same message
(data abort vector)
What should I try next?
-Chris
#239074 - 27/10/2004 21:10 Re: Player not booting [Re: cob666]
This is with the disk drives completely unplugged from the player?
If so, it's time for Stu or Rob to get their hands on it.
#239075 - 27/10/2004 22:51 Re: Player not booting [Re: tfabris]
cob666
I'll try one more time with the drives NOT connected to the board and then I guess I'll have to send it in <GULP>
Thanks for all the help guys!
-Chris
#239076 - 28/10/2004 00:32 Re: Player not booting [Re: cob666]
I wonder if you are getting it into kernel download mode or not.. Tony, how can he tell if the thing is successfully downloading a kernel or not?
#239077 - 28/10/2004 09:54 Re: Player not booting [Re: mlord]
cob666
I'm getting the progress indicators and the smiley face in the logo editor program when I flash the kernel. Also, I still haven't removed the drives and reflashed the kernel. I'll do that after work today.
-c
#239078 - 28/10/2004 14:49 Re: Player not booting [Re: mlord]
Smileyface.
I can't imagine a situation where the kernel flash would fail yet still give a smiley face. That smiley face only appears when upload.exe successfully sent every packet and got every proper receipt handshake in return.
Now, that doesn't mean it thinks the kernel file was a good kernel. It never examines the kernel file or does any sort of validation on its contents. You could send it a JPG of Claudia Schiffer and it would still give you the happy face.
Which is why I wanted to make certain he downloaded it with a browser that never inserts CRLFs into the downloaded files. (The Netscape-family browsers when run on the Windows platform sometimes will do that on a binary file if the server's MIME types aren't set right. They're doing the correct thing according to spec, and IE is deliberately breaking spec in that case, but at least it never inserts CRLFs into a binary file.)
#239079 - 28/10/2004 17:33 Re: Player not booting [Re: tfabris]
mtempsch
To be completely sure, run md5sum (can be had for instance here) on the file and post the checksum + exactly which file (URL/version etc) being used, and someone else here, having hopefully loaded the same successfully, can do the same and confirm if it's OK or not...
#239080 - 01/11/2004 20:53 Re: Player not booting [Re: mtempsch]
cob666
Here is the response I got when running md5sum
C:\Temp\Rio>md5sum v413.hijack.mk2.zimage
215c920ce353441c3f7fe45c894d1fcf *v413.hijack.mk2.zImage
I downloaded the zimage file from here:
http://empeg-hijack.sourceforge.net/ and selected the pre-built kernel for all mk2 players.
-Chris
#239081 - 01/11/2004 21:02 Re: Player not booting [Re: mtempsch]
cob666
OK --
Tried to flash one more time, this time with no HD connected. Got the smiley face, disconnected power supply, reconnected after opening HyperTerminal and get this:
empeg-car bootstrap v1.02 20001106 ([email protected])
As you can see, I no longer get the data abort vector message but then again, it looks like the kernel isn't loading.
Any more suggestions?
-Chris
#239082 - 01/11/2004 21:07 Re: Player not booting [Re: cob666]
I get the same checksum, so the file is good. Or at least, the file is the same as what Mark intended you to download.
Another thought occurred to me:
I think it might be possible that your serial cable is bad, but only on the TX line. In other words, there is some garbage getting mixed up on the TX line, but the "receiver" program in the empeg isn't validating the data so it doesn't know any better. Can anyone debunk this theory?
#239083 - 01/11/2004 21:14 Re: Player not booting [Re: tfabris]
A quick check would be to try and reflash it from another computer. Given that you are able to get into the self-test and view output, I would think the TX and RX lines would be okay. But another machine might be a worthy experiment.
Also, I would want to verify that you are using the original upgrader and upgrader developer image, that you have the empeg powered off and plug it in when asked. That can sometimes get you past any bad kernel that may have been there previously.
#239084 - 01/11/2004 21:25 Re: Player not booting [Re: pgrzelak]
He's definitely already doing those things since he gets the happy face in logoedit.
I agree trying it from another PC is a good idea.
#239085 - 01/11/2004 22:12 Re: Player not booting [Re: tfabris]
cob666
I'll try a different PC and let you know how it goes!
-c
#239086 - 01/11/2004 22:13 Re: Player not booting [Re: tfabris]
The other possible reason for the error is bad RAM, or a botched attempt at a memory upgrade.
#239087 - 01/11/2004 22:15 Re: Player not booting [Re: mlord]
He said his player passed the Ctrl-T RAM test. But bad flash might do it...
Does anything appear on the player's screen when the error happens? Has the player worked normally in the past?
#239088 - 01/11/2004 22:52 Re: Player not booting [Re: tfabris]
cob666
The player worked PERFECTLY fine until Friday. It worked in my car and then didn't work when I plugged it in to synch some new music. The screen is totally blank and I already checked the nipple and the ribbon cable to the screen.
-c
