#245493 - 05/01/2005 17:16 Need Help: Emplode Has Encountered Problem
Gallagher419
Ok today I got my MkII and I installed the software from the software install cd. It told me to upgrade to a newer version of software for the player so I did and when I start up the new version of Emplode everything boots up and as soon as it's done I get this message:
"Rio Emplode has encountered a problem and needs to close. We are sorry for the inconvience."
Error sig
Appname: emplode.exe
Appver: 2.0.19.00
Modname: emplode.exe
Modver: emplode.exe
Offset: 0005a70
After this all it does is shut emplode down. I am running Windows XP on my computer. Can anyone help I can't seem to find an answer in the FAQ section. Thanks in advance! BTW this is my first time owning an MkII.
I also forgot to mention that sometimes when I open up Emplode and the player is highlighted when I click ok it tells me that the player doesn't appear to be connected but it is plugged in via usb.
Edited by Gallagher419 (05/01/2005 17:23)
#245494 - 05/01/2005 17:58 Re: Need Help: Emplode Has Encountered Problem [Re: Gallagher419]
Qtqc
Hey, have you tried connection via ethernet?
#245495 - 05/01/2005 18:14 Re: Need Help: Emplode Has Encountered Problem [Re: Gallagher419]
matthew_k
Did you upgrade both the player firmware and emplode?
#245496 - 05/01/2005 19:28 Re: Need Help: Emplode Has Encountered Problem [Re: Gallagher419]
That is definitely this problem.
See if solving that problem also solves your crashing problem, too.
Make sure that you have put software version 2.0 final on the player, and that your Emplode version is also 2.0 final.
