#245778 - 07/01/2005 07:57 Emplode Crashing on Win2k and Windows XP
Bill Walker
Loc: NZ
Hi all,
I'm running V2.0 of Emplode and the RioCar Software on a Mk2 and everytime I try and add new files it bombs. Not much to go on but I have about 4GB of music on there and about 9GB Free. No matter what I try to upload emplode bombs. When emplode does bomb the empeg powers down.
Anyone got any pointers?
Thanks,
Bill
MK II, (Blue but should be Amber) SN: 118
MKIIa
#245779 - 07/01/2005 14:11 Re: Emplode Crashing on Win2k and Windows XP [Re: Bill Walker]
Bomb how? Crash? Stop responding? Does it produce any error messages? How does the empeg "power down"? Blinking LED? Was it saying "synchronizing" before then?
#245780 - 07/01/2005 19:16 Re: Emplode Crashing on Win2k and Windows XP [Re: Bill Walker]
Check to make sure it's not just this problem.
#245781 - 07/01/2005 20:28 Re: Emplode Crashing on Win2k and Windows XP [Re: wfaulk]
Bill Walker
Loc: NZ
Basically Emplode comes up with the nice windows debug, this program caused an error, do you want to send the info to MS. And the empeg says syncronizing before it happens, then when it does, it powers down completely (no blue led)
And I'm accessing the EMPEG over Ethernet and have the same problem on xp and 2k so I suspect its a problem with the empeg.
MKIIa
#245782 - 07/01/2005 20:44 Re: Emplode Crashing on Win2k and Windows XP [Re: Bill Walker]
Please post a boot log. The only times I have had emplode crash like that is if the music partitions are not mounted on the player (possibly due to damage or fsck problems) but the root partition mounted successfully.
#245783 - 08/01/2005 22:18 Re: Emplode Crashing on Win2k and Windows XP [Re: pgrzelak]
Bill Walker
Loc: NZ
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.14-rmk5-np17-empeg52 (rob@aphex) (gcc version 2.95.3 20010315 (release)) #11 Tue Apr 1 18:49:59 BST 2003
empeg-car player (hardware revision 9, serial number 10101915)
Command line: mem=16m
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004d80).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hdb: IBM-DJSA-210, ATA DISK drive
hda: IBM-DJSA-210, ATA DISK drive
hda: IBM-DJSA-210, 9590MB w/384kB Cache, CHS=19485/16/63
hdb: IBM-DJSA-210, 5729MB w/384kB Cache, CHS=12416/15/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:07:7b
Partition check:
hdb: [PTBL] [730/255/63] hdb1 < hdb5 hdb6 > hdb2 hdb3 hdb4
empeg-pump v0.03 (19980601)
Mounting proc
Starting player
Vcb: 0x4086d000
^A^H
Edited by billw (08/01/2005 22:18)
MKIIa
#245784 - 09/01/2005 10:53 Re: Emplode Crashing on Win2k and Windows XP [Re: Bill Walker]
Hm... At quick glance, that looks fine. Does the player work normally with any existing music? You mentioned that you are going over ethernet. Can you...
a) try doing a hyperterminal capture of the console while the sync is happening to see if there are any error messages?
b) try doing a sync with USB to eliminate ethernet as an issue?
c) diable any and all third party software that may have an open file on the player - making it so emplode cannot dismount the filesystems.
d) do a manual disk check to eliminate that as the source of any problem?
Thanks.
#245785 - 09/01/2005 20:10 Re: Emplode Crashing on Win2k and Windows XP [Re: pgrzelak]
Bill Walker
Loc: NZ
Yes it does...
Hmm just tried and it worked fine.... it's a different cable though, so I'm wondering if the previous one was faulty.
Ok, well USB started off working.... then bombed...emplode crashed as before...this time the empeg powerd down to flashing led, but would not turn on when button pressed... I'm guessing that because it went into bash rather than the player.
e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
ext2fs_check_if_mount: No such file or directory while determining whether /dev/hda4 is mounted.
ext2fs_check_if_mount: No such file or directory while determining whether /dev/hdc4 is mounted.
. server_protocol_handler.cpp:1386:Timeout during synchronise, restarting player
[21] player: old system call.
Function entered at [<0208dd38>] from [<0205ef70>]
r10 = 02153EC4 r9 = 00000000 r8 = BDFFFD20 r7 = 021A0964
r6 = 021A08F8 r5 = 00000000 r4 = 021A0940
Function entered at [<0205eed8>] from [<02069664>]
r10 = 02153EC4 r9 = BDFFFD0C r8 = BDFFFD20 r7 = 02154070
r6 = 0216BF6C r5 = 00000000 r4 = 0216BEC8
Function entered at [<020695d4>] from [<02066628>]
r7 = BDFFFD1C r6 = 02153DE8 r5 = 02154070 r4 = 02153DE8
Function entered at [<020665cc>] from [<02066db0>]
r5 = 02153EC4 r4 = 02153DE8
Function entered at [<02066d84>] from [<020670cc>]
r4 = 00000000
Function entered at [<02066e90>] from [<02066de8>]
r10 = 020AD438 r9 = 02153DE8 r8 = 0000340E r7 = 00000080
r6 = 0000000E r5 = 02153DE8 r4 = BDFFFD64
Function entered at [<02066dd8>] from [<020ad4f0>]
Function entered at [<020ad438>] from [<020b4824>]
r5 = 02153E00 r4 = BDFFFE40
Function entered at [<020b475c>] from [<020e9bbc>]
r4 = 00000000
Function entered at [<020e8330>] from [<020b45a0>]
r8 = 021573B4 r7 = 021573A0 r6 = 020AD438 r5 = 00000007
r4 = 00000000
Function entered at [<020b44f0>] from [<020e9bbc>]
r5 = 00000000 r4 = 00000000
Function entered at [<bffffcbc>] from [<021af9d8>]
Restored terminal settings
Abnormal player termination
Player received signal 4
Starting player
! tags.cpp : 61:Failed to open tags (0xc0041002).
Vcb: 0x4086d000
the filesystems.
At present it is the pure developer image on there...
Done.... after the above.... will try again tonight
MKIIa
#245786 - 09/01/2005 22:47 Re: Emplode Crashing on Win2k and Windows XP [Re: Bill Walker]
I find this particular line very curious...
It seems almost as if you had a mismatch between the emplode version and the player version. The boot of the player looks like 2.0 though. Please double check the driver installation for (possibly even reinstall) the USB driver set, per Tony's message above. It looks like it is timing out on a protocol message...
Another thought, after the fsck, is to manually allow the databases to rebuild on the player first. This should not matter, but it would not hurt anything.
Lastly, just for kicks, enable sync via the serial port and try to sync that way. Obviously you do not want to send any files up, but you might be able to just "touch" a playlist or something and force the sync. It would be a good test to eliminate the protocol and player versions vs. ethernet or USB issues.
#245787 - 10/01/2005 07:23 Re: Emplode Crashing on Win2k and Windows XP [Re: pgrzelak]
Nope. What that line means is that emplode crashed. The player got fed up waiting for it, and rebooted. The 'player: old system call' is a warning message from the kernel -- it's using a deprecated syscall to do something (probably the reboot).
#245788 - 10/01/2005 07:43 Re: Emplode Crashing on Win2k and Windows XP [Re: pgrzelak]
Bill Walker
Loc: NZ
Will give those a go tommorow... have to finish some truck strengthening tonight...
MKIIa
