#246579 - 16/01/2005 19:09 upgrading ram - what do i need?
CrackersMcCheese
Decided to up the memmory in my 2.5 year old dell dimension 4500 to 1gb from 512mb. Trouble is I have no idea what i need - all these different speeds and other numbers :S
I have 2 slots both occupied just now with what i think is ddr. I'd like as fast as possible. Help appreciated.
#246580 - 16/01/2005 19:14 Re: upgrading ram - what do i need? [Re: CrackersMcCheese]
Ezekiel
Loc: NH USA
I'd take a look at crucial.com - they have a pretty good system selector & good prices/service. They also have decent explanations of what all the numbers mean.
-Zeke
WWFSMD?
#246581 - 16/01/2005 19:21 Re: upgrading ram - what do i need? [Re: Ezekiel]
CrackersMcCheese
I've just went to dell support and put my system in there under uogrades. They list 512 MB - DIMM 184-PIN - DDR - 266 MHz / PC2100 - 3.3 V - non-parity.
Does this mean I must stick with memory with these figures or can i go higher?
I'll check crucial.com, thanks.
Edit: Crucial says I need 2.5v but Dell states 3.3v. Who's correct?
Edited by Philip O'Hare (16/01/2005 19:27)
#246582 - 16/01/2005 19:29 Re: upgrading ram - what do i need? [Re: CrackersMcCheese]
Dviant
IDoes this mean I must stick with memory with these figures or can i go higher?
Higher rated DDR ram will likely work in your machine (PC2700, PC3200), but you wont see any improvement in your system performance (unless you are into overclocking, and being you have a Dell I'm guessing not). Being the higher rated ram is usually more expensive you are better off just getting the PC2100.
Crucial isnt a bad place to order RAM, btw. Ive had a few sticks in various machines that have lasted me a long, long time with no problems.
Good Luck.
#246583 - 16/01/2005 19:37 Re: upgrading ram - what do i need? [Re: CrackersMcCheese]
CrackersMcCheese
Any ideas on the voltage thingy?
#246584 - 16/01/2005 19:50 Re: upgrading ram - what do i need? [Re: CrackersMcCheese]
Ezekiel
Loc: NH USA
Hard to say, I'm no expert (someone else here might know).
It's been my experience that the prices Dell charges for RAM are quite high.
-Zeke
WWFSMD?
#246585 - 16/01/2005 19:52 Re: upgrading ram - what do i need? [Re: Ezekiel]
CrackersMcCheese
yes dell is expensive - i just went there to see what they recommend. I've found 2 x samsung ddr 512mb chips on ebay for £90 but am worried about this voltage issue.
#246586 - 16/01/2005 20:03 Re: upgrading ram - what do i need? [Re: CrackersMcCheese]
AndrewT
Loc: Oxford, UK
Are you certain that you didn't mis-read something on crucial.com? There's a specification parameter that you sometimes see called CL (CAS Latency) - perhaps Crucial were trying to specify CL2.5 as opposed to 2.5v? It's a bit of a long shot I admit.
You could also check what Kingston suggest for your Dell (www.kingston.com).
#246587 - 16/01/2005 20:24 Re: upgrading ram - what do i need? [Re: AndrewT]
CrackersMcCheese
Screengrabs from Crucial and Dell respectively...
Edited by Philip O'Hare (16/01/2005 20:25)
#246588 - 16/01/2005 20:36 Re: upgrading ram - what do i need? [Re: CrackersMcCheese]
AndrewT
Loc: Oxford, UK
A PITA I know but I recon your best bet is to Google on the part number for the RAM chips fitted to your current DIMM module and try to find a datasheet on them.
#246589 - 16/01/2005 21:55 Re: upgrading ram - what do i need? [Re: CrackersMcCheese]
One of the really good things about Crucial is that if you buy using the memory chooser for a particular machine they guarantee that it will work. I use them for all my ram (except the stuff in mini-itx boxes where I stick with the stuff from mini-itx.com, because physical space can be a problem and I know their ram boards have been tested for size).
#246590 - 17/01/2005 05:17 Re: upgrading ram - what do i need? [Re: CrackersMcCheese]
Dviant
Err... I googled the specs of a Dimension 4500 and it states that the board only has 2 ram banks total. You said you have 2 slots populated giving 512 (256 *2) so that means if you want 1GB of memory you would need to buy two 512MB sticks. Hope you realized that!
If thats the case I wouldnt worry too much about the voltage issues. You are going to wind up buying a matched pair or RAM, so there wouldn't be a conflict.
Anyway, I find it hard to believe that the RAM you listed is actually 3.3v. DDR RAM's specification limits the voltage to 2.5. I can't even think of a RAM manufacturer (currently) whose sticks can take that voltage for long with out letting the smoke out. But like I said, I wouldnt worry about it.
Browsing name brand memory I found that PC2100 RAM is more expensive than PC3200 (by ~$10 a stick). Running PC3200 ram on a board that only supports PC2100 should be ok, but I can't guarantee it will work with your Dell.
#246591 - 17/01/2005 07:31 Re: upgrading ram - what do i need? [Re: andy]
Not wishing to hijack Phil's thread (but I am ). I've decided to stick 512MB in my iBook (bringing it to 768). I looked at crucial.com and found a 512MB SO-DIMM for £82. Looking at the specs I can get a similar Corsair module for £58. Now, I've never upgraded laptop memory before. I've stuck with Corsair for last few upgrades and I haven't had a failure yet. They both offer lifetime guarantees (for what they're worth) which would you guys go for?
#246592 - 17/01/2005 08:22 Re: upgrading ram - what do i need? [Re: andym]
Dviant
Eh its all RAM.
Corsair isnt a bad company and makes pretty decent RAM, but I have had a stick of Corsair in he past (~5years) that failed for no apparent reason on my part. But I think Im an oddity. Dont hear about too many such problems.
Course stupid me didn't know they had a lifetime warranty. Figures.
Honestly, I would go with the Corsair considering the price difference. Can't offer any advice on the install though. Have never really tinkered much with lappys.
Sure it will play nice with the existing ram though? Even if it doesn't you will have more than you started with I guess.
#246593 - 17/01/2005 11:44 Re: upgrading ram - what do i need? [Re: CrackersMcCheese]
Ezekiel
Loc: NH USA
Phil,
One other thought, check the version on you BIOS and then check the release notes on the most current BIOS offered by Dell to make sure that one of the intermediary revisions didn't change to support large amounts of RAM. I upgraded a Dell workstation a few years back that required a BIOS upgrade in order to take 1 GB. If you stick in the new RAM and it won't boot, a new BIOS might cure it. Dell's BIOS installs are painless, IIRC.
-Zeke
WWFSMD?
#246594 - 17/01/2005 15:42 Re: upgrading ram - what do i need? [Re: andym]
Happy Birthday wfaulk
I had two pairs of desktop memory (I forget what exact type now) from Corsair fail on me out of the box. Pain in the ass. But they replaced them with no compunction whatsoever and everything's just fine now.
