After many problem free years, my trusty Empeg has gotten sick. I have no control at all from the buttons nor the knob. The remote fails to elicit any response from the unit as well. I also tried using the Sony stalk I have hooked into my tuner, but the results were the same. The only way to access any kind of control from it is to use the usb or network connection to either Emplode/jEmplode or the web interface (cushman or charcoalgray99's).
After using the web interface, the Empeg will boot back up where it left off at, but then stops right there (unless a playlist had been selected and started already) and continue no further.
Anyone have any ideas what could be causing this? I'm including a copy of the bootlog as well in case some info can be found within it.
________________________________________________________________________________
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v417 (hijack@rtr.ca) (gcc version
2.95.3 20010315 (release)) #2 Sat Jan 15 19:12:21 EST 2005
Processor: Intel StrongARM-1100 re
Checking for extra DRAM:
c0c00000: wrote ffffffff, read e91ba9f0
empeg-car player (hardware revision 7, serial number 80000150) 12MB DRAM
Command line: mem=12m
Memory: 10952k/12M available (984k code, 20k reserved, 328k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 20706d65 'emp '
Found custom animation at offset 0x9c37c
Tuner: loopback=0, ID=-1
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005e00).
empeg RDS driver initialised
RAM disk driver initialized: 16 RAM disks o
empeg single channel IDE
Probing primary interface...
hda: IBM-DARA-212000, ATA DISK drive
hdb: IC25N030ATDA04-0, ATA DISK drive
hda: IBM-DARA-212000, 11513MB w/418kB Cache, CHS=23392/16/63
hdb: IC25N030ATDA04-0, 28615MB w/1806kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:10:00:9
6
Partition check:
empeg-pump v0.03 (19980601)
Timezone: GMT
do_kexec: failed, errno = -1
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
Vcb: 0x4054d000
