#248316 - 01/02/2005 23:32 BMW / Mini antenna adaptor
I need to find an adaptor that will convert the antenna connection in my Mini to the kind on the empeg tuner. I can get one that goes from the Mini to an american style antenna plug but then I would need a second adaptor.
If you don't know where I can get one does anyone know what the plug on the empeg tuner is called ?
#248317 - 02/02/2005 01:21 Re: BMW / Mini antenna adaptor [Re: msaeger]
robricc
I think this is what you want.
http://www.crutchfield.com/S-HfERMdQCVAF/cgi-bin/ProdView.asp?g=113800&I=097DIN3
Notice I said think. Wait for a 2nd opinion before ordering.
#248318 - 02/02/2005 01:32 Re: BMW / Mini antenna adaptor [Re: robricc]
That looks like the adaptor that comes with the empeg tuner. I should have taken a picture of the back of the stereo.
The antenna plug looks like a XM radio antenna connector like this . So I need one that goes from that to the kind on the empeg tuner.
The ones I have found have the goofy plug on one end and the kind most american head units use on the other. I could use one of those but I would need a second adaptor to connect it to the empeg tuner.
#248319 - 02/02/2005 01:57 Re: BMW / Mini antenna adaptor [Re: msaeger]
Here is another one. I need this with the female end replaced with the end to connect to the empeg tuner.
#248320 - 02/02/2005 13:58 Re: BMW / Mini antenna adaptor [Re: msaeger]
Couldn't you just use that along with the antenna adapter that came with the empeg? I know it's not ideal, but....
#248321 - 03/02/2005 00:29 Re: BMW / Mini antenna adaptor [Re: wfaulk]
Yeah if I can't find the cable I am looking for I will have to use two adaptors.
