#249427 - 15/02/2005 17:44 hijack EXEC (ONCE)
ukengb
Loc: United Kingdom
Can someone point to me to a definition of the difference between hijack's @EXEC and @EXEC_ONCE config.ini options?
I just cannot find anything that actually explains the difference, so a pointer would really help.
Thanks.
#249428 - 15/02/2005 17:51 Re: hijack EXEC (ONCE) [Re: ukengb]
@EXEC executes the given command every time the player app starts.
@EXEC_ONCE does it on power up and that's it.
(I think that's right.)
I can't find an immediate definitive link. It seems that the Hijack FAQ is less than up-to-date.
Edit: Here you go.
Edited by wfaulk (15/02/2005 17:56)
#249429 - 16/02/2005 06:36 Re: hijack EXEC (ONCE) [Re: wfaulk]
ukengb
Loc: United Kingdom
That would make sense as the recommendation for telnetd was @EXEC_ONCE and for running ntpdate was @EXEC.
When the empeg 'sleeps', is the player app still running or has it been terminated and it only starts again when you wake up the empeg?
I just answered that - it's still running. I have 14 player processes - is that right, how come so many?
Under what circumstances would the player app be stopped?
#249430 - 16/02/2005 07:09 Re: hijack EXEC (ONCE) [Re: ukengb]
One per thread, probably.
#249431 - 16/02/2005 13:08 Re: hijack EXEC (ONCE) [Re: ukengb]
- When you Q or Ctrl-C or kill at a shell prompt.
- When you use a configuration tweak to add the "Quit" item to the player's main menu, and then select it from the player's main menu.
- When the player app crashes for some reason.
I'm not sure if the player app stops at any point during a synchronization operation, or if the player just receives a reboot command...
