#252379 - 23/03/2005 14:20 Hijack v418: Onscreen crash messages
Hijack v418 is now released: the "geriatric player" release!
This version now dumps a 20-second popup message to the front display whenever a serious internal error is detected:
-- player crashes (various reasons displayed)
-- hard disk errors
-- kernel crashes (most, but not all)
As more and more of our players age, they may experience sudden slowdowns and glitches in the car, which until now were very difficult to diagnose. No more!
If you see one of these terse error popups, please make note of the message, to report it here later here for interpretation.
EDIT: Okay, good to go. For a moment I thought it might be DOA, but it turns out I was loading a Mk1 kernel onto my Mk2a (blush)
Edited by mlord (23/03/2005 14:29)
#252380 - 23/03/2005 14:29 Re: Hijack v418: Onscreen crash messages [Re: mlord]
No issues after all. Go for it!
#252381 - 23/03/2005 16:47 Re: Hijack v418: Onscreen crash messages [Re: mlord]
SE_Sport_Driver
I know this was mainly for Tony (and a few others) but thanks for making this public and for all the work you've put into Hijack!
#252382 - 23/03/2005 21:31 Re: Hijack v418: Onscreen crash messages [Re: SE_Sport_Driver]
Snowshoe
Loc: Midwest
Here, here! My sentiments exactly.
#252383 - 23/03/2005 21:47 Re: Hijack v418: Onscreen crash messages [Re: mlord]
Mmm.. missed one of the out-of-memory messages, so I'll issuing v419 shortly to cover that case as well.
#252384 - 24/03/2005 06:53 Re: Hijack v418: Onscreen crash messages [Re: mlord]
cwillenbrock
Loc: Dover, NJ
You're pretty cool, Mark.
- Chris Orig. Empeg Queue position 2
#252385 - 24/03/2005 18:44 Re: Hijack v418: Onscreen crash messages [Re: cwillenbrock]
mcomb
Loc: San Carlos, CA
Oooh, this will be handy. Thanks Mark!
#252386 - 25/03/2005 02:00 Re: Hijack v418: Onscreen crash messages [Re: mlord]
Let it be known:
MARK LORD IS THE MAN.
Thanks, Mark, this is extremely cool.
I'm running that version now, if the player freezes playback again, we'll know if it's a hardware fault right away.
#252387 - 26/03/2005 18:13 Re: Hijack v418: Onscreen crash messages [Re: mlord]
Micman2b
Loc: Central, NC, USA
I am guessing this message is a failing hard drive but this is what I am getting:
hda: disk error: read_intr
Any way to tell which drive is failing?I checked all cabling this morning but found nothing loose. I have two new 100gb drives on order.
Symptoms have been UI lockups, file corruption and sound glitching within the past few weeks. Mark put out the new HiJack just in time for me to test...
#252388 - 26/03/2005 18:25 Re: Hijack v418: Onscreen crash messages [Re: Micman2b]
Yes. I think that HDA means the first "Master" hard disk, the one without the jumper.
Of course, it doesn't necessarily mean the disk is bad. I'm sure at this point, I don't need to give you the link to the FAQ entry on what to look for, but there it is anyway.
#252389 - 26/03/2005 18:32 Re: Hijack v418: Onscreen crash messages [Re: tfabris]
Micman2b
This player has been soldered and has had cable replaced also. I am getting the dreaded drive clicks now that it is safely inside in a quiet place. At least it is not a component on the empeg board.
My spare will get some use it seems for the next few days(weeks)...
Is there a list of possible failures that can be added as reference to this thead?
Sean
#252390 - 01/04/2005 00:38 Re: Hijack v418: Onscreen crash messages [Re: mlord]
Jemmi
I got a "sigkill error" today... I was trying to go to the next song when it happened... what does this mean?
#252391 - 01/04/2005 05:42 Re: Hijack v418: Onscreen crash messages [Re: Jemmi]
AudunE
Loc: Trondheim, Norway
I have also had a couple of these when switching to the next song... Don`t know why this signal is sent.
- Audun E -
#252392 - 01/04/2005 20:16 Re: Hijack v418: Onscreen crash messages [Re: AudunE]
Mmm.. kernel page fault error.. possibly due to running too low on memory.
#252393 - 02/04/2005 00:31 Re: Hijack v418: Onscreen crash messages [Re: mlord]
Jemmi
Then I should increase the cache? Currently it's at normal with no adjustments through Hijack
